Pot still column design
Getting my ideas in order for a build. If a guy were to use a triclover clamp to join a 2" copper column to a keg and that column was about 18" tall would it be advisable to use a 2" 90 degree elbow followed directly by a 2" to 3/4" reducer? The plan would then go to a 6" long piece of 3/4" to a union that joins a 36" long 3/4 over 1/2 liebig to that section. Is that abrupt size change after a 90 likely to be a problem? Done lots of reading and haven't seen this addressed, apologies if my search skills have failed me.
Re: Pot still column design
It’ll work. There are many potstill heads very similar to your proposed configuration.
The vapor velocity in the riser will be slow, as the speed will be limited by the 3/4” line to the Liebig. But it will work.
An oversized shotgun cooler may be better. The less reduction in the vapor path, the smaller the passive pressure build up before the bottle-neck. And its the bottle-necks that define total system performance.
To get from your upward riser to the downward cooling trajectory, use a gradually bent pipe rather than for instance two pieces of each dead-on 90 degree angles. For the same reason as above.
If you go oversized shotgun cooler, you need less space on the downward cooling trajectory. And you can do with a shorter riser. A shorter riser equals less energy losses and less passive reflux (drops falling/running back from your riser to your boiler), thus improving your overall system efficiency, translating to better control over cuts and slightly shorter run times.
Regards, Odin.
Regards, Odin.
- MoonBreath
Both ends can dictate/ manipulate flavor and speed.
I'd suggest most folks using 2" base would find the 3" is way faster and more flavorful.
More concentric.
More concentric.
- Twisted Brick
+1MoonBreath wrote:Both ends can dictate/ manipulate flavor and speed.
More concentric.
The first pic is an example of a shorter 3" riser and gradually-bent still head into a 2" shotgun condenser. The objective of this design was to minimize the pressure buildup Odin referred to, which occurs whenever vapor encounters a reduction on tube diameter or a corner (hard 90* = higher resistance). I believe this pressure buildup, wherever it occurs within the vapor path, backs up to the boiler, upsetting the smooth, gradual phase change of the boiler constituents, creating smearing, prior to exiting the boiler. This vapor pressure can be mitigated through power management, resulting in a reduction of takeoff speed.
If I ever get around to it, I would like to have a buddy with a metal spinning shop try to smooth out a standard 3x2" reducer to look like pic #2.
Not sure how old you are, but planning for all of your elevations based on a counter top collection height is more helpful than not,,,when you're old.
Thank you very much for all the information and insight. To address some of the back story, it's my first rig. I am a very casual user when it comes to hobbies, i.e. I enjoy many and can't commit to just one. That leaves me with enough time to keep it very simple when I begin a new one. I plan to try and use this thing about 4 times a year max so I'm willing to sacrifice some time running it for a simpler construction. It'll be used solely for cider or corn washes and I may never do any redistillation as I'm quite content with a lower abv. The liebig looks like something I can easily tackle and keep satisfied with for a while. The simplicity of rigs like that is what brought me here. Thank you all so much. I'll post some pics when complete.
You would also have to be content with the inferior flavors from a single run.Chevyman wrote:It'll be used solely for cider or corn washes and I may never do any redistillation as I'm quite content with a lower abv.
- MoonBreath
You'll prolly be the only person drinkn the singlins...
Won't be strong enough for most...Also lots of ferment flavors carry over there that are not whiskey like.
Very mediocre at best.
I guess I'm surprised to hear that. Not saying you are wrong just surprised. I've had several quarts of corn mash from a friend's similar pot still that were singlins and they were enjoyed by myself and others. I guess there is probably a reason why everyone redistills. I must have an inferior palate!
- MoonBreath
Not sayn it can't be done..Older threads talk about folks liken singlins, also Usge talkn about gettn 130proof on a single run,
but I couldn't do it with a simple pot still...Have to really do it slow and be a good wash, but try throwin that singlin in with some fresh wash and run it.
Be gooood then for ya.
2 runs instead of 3.
Many years I've only done four runs. One ferment, three stripping runs and a spirit run, a weekend of hard out distilling producing plenty of fine product, then the still broken down and stored for a year.
