Beer keg pot design question
Plumberjohn
Post by Plumberjohn »
Im wanting to put an old beer keg back into service as a still pot. Ive seen some designs where a 4" sanitary was installed on the side of the keg. Ive also seen where folks have replaced the 2" top flange with a 4" sanitary so it doubled as a clean out.
My question, is there any distilling advantages or disadvantages to using a 4" column as opposed to a 2" column on this size pot?
zed255
Re: Beer keg pot design question
Post by zed255 »
Short answer (and a fairly common question too) is no. I use a 6" ferrule on my keg for accessing the interior and use a cap reducer to put whatever I need on top. I like 2" for pot stilling mainly because it is sturdy without being grossly oversized, but it isn't really necessary that you use even that large.
Zed
Plumberjohn
My main reason for the larger opening is for cleaning purposes so I guess its a preference choice as to having it on the side or top. Im trying to decide on a final design before drilling, cutting and welding.
Thank you for your insight!
You really dont need a large opening for cleaning......mostly boilers only need a quick rinse out with a hose.
Lots of people have run the original size keg hole for many years without a problem.
Tummydoc
Post by Tummydoc »
I've never seen the clean out on the side. Off center on top is easiest and works as a fill port and clean out. Also allows you to keep column mounted. Don't forget a drain port on the bottom or lower edge of side.
Bill is right, I fill, drain, and hook column to the original Sanke. But if I could TIG ......
Twisted Brick
Post by Twisted Brick »
Plumberjohn wrote: Sun Mar 14, 2021 7:43 am Im wanting to put an old beer keg back into service as a still pot. Ive seen some designs where a 4" sanitary was installed on the side of the keg. Ive also seen where folks have replaced the 2" top flange with a 4" sanitary so it doubled as a clean out.
Cleaning/filling benefits aside, a 4" ferrule provides the ability to run different-sized riser/columns, an un-restricted riser for a downtube if you someday convert it to a thumper, and lastly, not having to fiddle with the half-assed gasket like the one I have on my unmolested 2" keg.
I originally thought of adding a 4" to the side of my keg like Badmotivator did, but instead went with a 6" on top (my arm won't fit in a 4"). I upgraded for the reasons above, but also because I suffered a second scorched (minor) strip run and removing the burnt carbon ring (I run NG) was a PITA.
The biggest disadvantage to 4" and larger ferrules and the pipe/fittings that go with them is cost. The other disadvantage is that once you've modified it, you can't revert to using your keg for its original function.
For those who elect to invest in upgrades (ie: ferrules, fill ports, drains, etc) these seemingly unnecessary improvements can translate to more-streamlined processes and a shorter distilling day.
4" ferrule
Badmo Boiler.jpg (20.41 KiB) Viewed 2130 times
Post by The Baker »
Many turn the keg over, use the 2" fitting for a drain and put a 4" or even a 6" in the (now) top.
More suited to electric than gas.
tiramisu
Post by tiramisu »
The downside of upside down is you lose the practicality of the handles if you are going to put a big port on top and put your pieces inside.
I'm still headed down the upside down route for ease of drainage but it is a compromise.
Plumberjohn
Thanks folks, i appreciate the different views.
Im at an age now that if there is something that will make things easier im all for it.
stmaus
Post by stmaus »
The only mod I made to my keg was a hole in the side for the element. I have no problem cleaning my keg, by just sticking a hose in the top (as Saltbush Bill noted).
Plumberjohn
Thank you all, I had a lot to brood over. I think im going to weld a 4" ferrule in place of the original 2" keg flange. I see where i can buy a 4"x2" end cap reducer which would give me the 4" access id like and a better 2" flange to work with. Going to 4" seems to give me more options even if i never use them its nice to know they are available.
Plumberjohn
So, this is what i finally decided on for my pot. I went with 4" on top and 2-1.5" on the front. 4" gives me size choices up and down. I also picked up a few other goodies over the past year and refined my condenser coil some. Pardon the junk in the spare room.
Toxxyc
Post by Toxxyc »
I actually had this discussion with a commercial distiller (small craft gin maker) over the weekend. He said that a 4" column on top of the still runs 4x more vapour than a 2", which means 4x faster stripping runs than a 2" if you're stripping. That might be worth it. I have a 2" on top of mine, and I'm considering either cutting it open to 4", or getting a 2" to 4" adapter to get a bigger column on top for stripping runs.
EricTheRed
Post by EricTheRed »
i use my 2" for potstill runs and the 3" for stripping and reflux - seems to work well
Life has gotten interesting!
Toxxyc wrote: Wed Dec 08, 2021 10:02 pm He said that a 4" column on top of the still runs 4x more vapour than a 2", which means 4x faster stripping runs than a 2" if you're stripping.
Not unless you put a heap more heat under it as well , size alone wont help.
BrewinBrian44
Post by BrewinBrian44 »
I read quite a bit on here and elected to do the upside down method, but welded on a 2” tri clamp ferrule for a clean gasket fitment instead of the standard flange. I also use a 4” ferrule on top with a reducer depending on what one doing. The beauty of using the top of the keg as a drain is because you can let gravity do the work and easily drain your keg without wrestling around with it to pour out the remaining liquid. I have a Blichmann riptide pump I use for everything and it works great to drain the boiling hot keg right after a run without any lifting. I even do my final hot water rinse with the pump turned on and never have to lift the hot keg.
Toxxyc
Post by Toxxyc »
Saltbush Bill wrote: Wed Dec 08, 2021 11:05 pm
True, but I'm stripping at less than the max of the element anyway, so I'm sure I can boost that quite a bit. If I can't - I can just swap out the element with a bigger one! :D
