Hey, just a quick question, I strip 2 30L turbo sugar washs down, cover the element with water chuck all the stripped booze in and re-destill to 95% at a rate of about 15 to 20 ml a minute, i have a 1200mmX50mm SS stack with copper scourers, and dont collect any thing over 79.5deg C (i stop when the flow rate gets below 10ml a min about 8 hours later and am yeilding a tad more than 1L of polished 40% per kg sugar) Am i running it too fast??? Am i getting greedy???.... I'm chasing the zero smell, no taste pure spirt, my booze tastes like vodka with a little bite and slight metho smell even after 2 weeks on carbon stirred daily then run verticaly up a 50mm collume of carbon at a rate of 2 drips a second (weeks!!!) any suggestions??? am i going to fast???? also....
How long do you let your stack run under full reflux before drawing off your heads??? does it matter when i'm getting 95%??? am i dragging my heads out by not giving it a few hours???? is this where my bite or slight tang is coming from or is it a "house flavor"?? I'm running out of things to try....... thanks for your replies
Whats your flow rate?? How long under total reflux
