rednose wrote:That would be ok for smaller builts which you disarm, clean and dry.
In bigger ones you would need a cleaning system and even with that the stuck water can mold and stink after a while, don't ask me why I know.
Great sucess today I worked all morning (regular job) then got home and started with what I have, water checked the shotgun dephlag 1 small leak that was easy fix,my top is concave while bottom has the tubes extended about 1?8 inch. Next I spent some time working on a layout for my 2" shotgun vapor condensor. Was able to save the 2"tube from my last atempt and made a new shotgun condesor which water tested and NOOOOOO leaks. So I proceded to finish up and plumb to the "arm" Now I'm on hold until I get some 4" couplers and reducer.
I'm very proud of you RC, you are doing a great job.
You will love your still, it's the most advanced in this dimension.
Joe
Throw us up more pics bro... would love to see your work.
KS
if im understanding right, your wanting to tapp the copper to us a SS screw in it? copper is pretty soft, and after a few uses, i would be afraid that it might strip out.... .
where the pics!!!!!!!!!
spooky
rockchucker22 wrote:My mapp gas won't seem to get the 4" that hot I can get smaller stuff hardsoldered easy it's the big stuff that I cant seem to get hot enough.
My friend was trying to fix a copper pipe into a copper cylinder (don't know what he used, it's outside my expertise but it was a hand-held gas torch and like a welding rod, likely the same as yours).
He had the same trouble, the heat was being taken away from the work area because of the size of the cylinder.
I said to him later that we could have got out the electric fan heater and played the heat near the work area; would probably have more than offset the heat loss?
Anyway it might be worth a try!
for the 4" you may need to use oxy accetylene, or a bigger map torch. Hey my pex supply order just shipped to day also.. I bet you ordered some 4x2 couplings and they were back ordered.
rockchucker22 wrote:I'm using 15% silver solder plus silver solder flux paste
OD
The welding shop said the hard solder would have a hard time sticking with the silversolder, The flux does say for copper, I think it is a boric acid paste to keep the copper from oxidizing.
I use a borax based flux with the 56% silver hard solder for structural joints in copper. You have to wait for the borax to actually melt by which time the copper will be glowing red. Flows perfectly and makes a great job but it takes some heating. I use MAP gas and with big bits of 2" have to preheat the entire workpeice somehow.
Mr.Spooky wrote:how did you end up connecting the deflag?????? pics???
LOL
spooky
I easy flandged it and will put a 4" tri clamp when it arrives, how long did that place take to ship to you?
a few is easy to do when your the distiller!
i cant remember how long it took, but it dident seem too long. just normal shipping time. they dident wast any time getting it out.
spooky
Mr.Spooky wrote:you should have talked them into shipping overnight!
spooky
Ha they said it will be here tomorrow or the next day! I bet monday.
if its worth having,,,,, its worth waiting for!
how do you plan to seal the connection between the deflag and the column??
i think that this removeable "tree" is the way to go!
spooky
rockchucker22 wrote:Tri clamps came a few min ago! She is a bueat. I promise pics and steam run tomorrow. I'm so excited,thanks to all who has helpped.
Oh Ya dont you love that feeling.... We will be looking forward to the pics..........
KS
