I placed the drain slightly above the plate. 1/4". It should be able to take almost everything but not collapse it. The valve is located near the bottom plate so that the line will fill with fluid first and offset vapor pressure. Fluid empties in to the middle of the first chamber.emptyglass wrote:Nice work MR.
I'll pencil it in for my column, pending your results with neutral making.
Is the spigot for the take off at the bottom of the top plate, or at the top of the downcomer? Does it take the "exess" from the top plate, or does it drain the plate?
I am going to increase the line size. I dont like to use any brass so I have been looking for a stainless valve. I think I have found a 3/8" npt valve on Grainger that will work.
I threaded some 1/2 copper (5/8"od) with 3/8 npt. That will allow me to screw the pipe directly into the valve reducing the amount of fittings needed.
Once I nail down the size needed to function perfectly fittings can be soldered to the exterior so that plate trees can still be removed when necessary.
Hang on just a little and I will get us a little closer KS. I am very pleased with the first results but want to do a little more before I make a strong recommendation. I do think it will make a huge difference on your five or six plater. I knocked up twenty gallons of Birdwatchers yesterday so the next tests are a couple of weeks away. That gives me time to find the valve and fittings I want to use.Kentucky shinner wrote:I think I am going to try some R&D down this road and a 6 plater also.
MR
