bottom of reflux
bottom of reflux
hi again , yes its the redneck newbie AGAIN lol
i made the still tonight , got a buddy to solder it up for me ,, he did a good job !!
i used tony design & on the bottom of the reflux tower he used screen copper mesh to hold the resin rings in , well from everything i read , alot if not most perfer stainless scrubbies and i too plan to use them
do i still need the screen wire over the bottom of the tower or could i just use a brass or copper rod solder over the bottom to hold the scrubbies in the tower ?
On my new setup my tower just slots into a brass fitting at the top of my boiler. I made a copper plate drilled with lots of 3/16th holes which just sits between the tower and boiler. I use stainles scrubbers which actualy tend to stay up in the 2" column anyway Probably just as well as just looked on my bench next to my still and noticed the plate sitting there and have almost finnished my 50 litre run lol. First run on this still as only just completed yesterday and had a few probs with cooling water and after getting vapour coming out the top we cut off the heat removed column took out a scrubber to place above condensor. Think I left the plate out after doing a steam/water run to clean out flux. Will be interesting to see if there are any scrubbers in my boiler when run is finnished.
Hic hic Now where did I put my glass
Re: bottom of reflux
First of all good choice on not using the rings. I have a bag full in my basement I have never even opened. Scrubbers give you much more surface area in a small column and I also just clamped a peice of wire onto the bottom of the column to assure me that the packing would not fall during a run. One word of advise though would be to use copper scrubbers or copper mesh for packing insead of stainless steel if you can. I am still using stainless but I do intend to switch to copper mesh on my next order to brewhaus.allen42 wrote:hi again , yes its the redneck newbie AGAIN lol
Dane Cook
Dane Cook
I don't know how much the mesh costs at brewhaus, but I just picked some copper mesh scrubbers up at wal-mart for $1.88 for a 2 pack. Unrolled, each scrubber is about 2-3 ft long.
I am trying to figure out how much I should use in the 18" column that I am going to use for my potstill.
"Be nice to America, or we'll bring democracy to your country."
"The best things in life aren't things."
"Imagination is more important than Knowledge"-Albert Einstein
Pothead,
Place a magnet on those scrubbers from Walmart and see if they are magnetic. I've never been able to find any at Walmart that were really copper, they always appeared to be copper coated.
You will need alot more than two scrubbers to fill a 2" column over three feet long. Yopu can get enough real copper to fill two columns for about $10 to $15 per 100 foot roll at Amstat Industries, Inc.
I've tried both this and brewhaus, and this stuff is less expensive and works great. Unroll about 24" and cut, then re-roll the 24" section to the shape of a cylinder and stuff into the column. Place enough cylinders to fill the column.
Damn. I wasted about $4.00 on magnetic scrubbers. Oh well, thatnks for the advice Grayson. The thing that gets me is that right on the package it says that they are "copper mesh scourers". False advertizing. It should say "copper colored mesh garbage"
unless you want to live and work in the usa for the next few decades.Grayson_Stewart wrote:Money is never wasted at Walmart
Walmart has a demonstrated policy of using a modified version of the "double lever" con to force mid sized US based manufacturers to move their operations to China.
They are a fiscally malignant force within the US economy.
But yeah... you can't beat their price on sugar.
"a woman who drives you to drink is hard to find, most of them will make you drive yourself."
anon--
anon--
Sorry for laughing pothead but may I just say to you "join the club". If you did not yet have these "copper colored mesh garbage" laying around under your kitchen sink then I think it was just about time. I use mine to scrub my internal element after a molasses run, lol. Copper mesh form brewhaus.ca cost $19.00 Canadian for a 36"x2" packed column. I think that's a fair price.pothead wrote:Damn. I wasted about $4.00 on magnetic scrubbers. Oh well, thatnks for the advice Grayson. The thing that gets me is that right on the package it says that they are "copper mesh scourers". False advertizing. It should say "copper colored mesh garbage"
Dane Cook
Dane Cook
There is a show being aired on PBS about this. I want to see it.Fourway wrote:unless you want to live and work in the usa for the next few decades.Grayson_Stewart wrote:Money is never wasted at Walmart
only six scrubbers I put 24 in mine and still need another ten I would say to fill itallen42 wrote:my wife picked up the SS scrubbies last night from wally world ! she got 3 boxes , with 2 in each box ,,
the plate seems like a good idea THANKS !!! , it would be easier to have a plate of sorts rather than extending the colum below the bowl i think !
I agree with NZ. How tall is your column if you are only using 6 scrubbers. If you have a scrubber that when made into a ball it is around 2 1/2" think it should take up about 3" in a 2" diameter column. So if your column is packed 36" and is 2" in diameter then you will need 12 scrubbers if it is packed 48" and 2" diameter then you will 16 scrubbers and so on. I would imagine that if your column is only 1" diameter each scrubber would take up 6" in your column so with 6 scrubbers you would get up to 36" of packed column.
Dane Cook
Dane Cook
Is it a linear graph where the same height of scrubbers gives you an additional plate each time? I get a huge jump in initial purity from two scrubbers (from 140 to 170 proof initial) and then have to pack the rest of the column to (46" total) to reach 190 proof. I've never graphed the proof increase with each additional scrubber but it would be interesdting to know.
I think it is linear, but each plate is less effective than the one before it.Grayson_Stewart wrote:Is it a linear graph where the same height of scrubbers gives you an additional plate each time? I get a huge jump in initial purity from two scrubbers (from 140 to 170 proof initial) and then have to pack the rest of the column to (46" total) to reach 190 proof. I've never graphed the proof increase with each additional scrubber but it would be interesdting to know.
If Leonardo da Vinci had a video camera.
If each theoretical plate is less effective than the preceeding theoretical plate then it wouldn't be linear would it? The purity would be aproaching the asymptote and you would need an increase in height of scrubbers to achieve an equal step in purity.
allen42 wrote:thanks for the scoup! i thought , yes thought lol that i had read 6 per 36" colum & *tease* them out ,, going to get 12 more !!!
thanks again
it all depends on the size and composition of the pads...
Real copper pads are a sort of sock ball made from tubular copper mesh. Its best with these to break the one little spot where the ball is bonded to hold it closed un-ball it, smooth it out and roll it loosely.
Stainless steel scrubbers are usually one continuous spiral winding all jammed together... like a tangled spring. These you want to tease out into the longest shape you can make that will fill your column.
In general the stainless scrubbers are far too dense to use as is.
There are also two main types of stainless scrubbers, the small household ones which are finer filiment and come in balls about an inch and a half in diameter and the professional resturant/industrial ones which are heavier guage and the ball is three to four inches in diameter.
anon--
anon--
