CCVM Column height advice needed
- ScotsPagan
Hey all,
I'm finally starting to put together my design for my first still;
Boiler will be a 50L beer keg with probably a 3KW water heater (depending on what's cheap) or 5KW...
Column will be 2" since there's already a 2" hole (plus 2" pipe Is easy to get here, compared to larger)...
But I'm stuck on how HIGH to make that column.
I get there's probably a formula that dictates height of column/diameter of the tube/total thermal input for the boiler etc. but. don't know what it is. Has anyone got a lead on that, or failing that, their own CCVM designs for column height (specifically of the packed column beneath the t-section?
I'll be operating in reduced space environment so a 2m tube isn't going to happen - 1.5m would be difficult but possible, so smaller the better - but obviously not so small I can't get reflux properly.
Also, whilst on the subject, how long should the section of pipe ABOVE the t-section be for my regulating condenser? Obviously large enough to fit the entire condenser in, covering the t-joint's "exit" hole but I don't know how big to make that condenser, so..
Thoughts?
Thoughts?
Re: CCVM Column height advice needed
1.2-1.3 will work you can go 1.5 and depending on the length of your RC longer may be better.
My CCVM has 1.2m of 2” packed column (SS scrubbers) and puts out 1.2 litres per hour at azeotrope. The boiler uses a 2200W element and I am usually running it at 1600W on the spirit run
Modular 2" Pot Still
- ShineonCrazyDiamond
Mine is .89 meters, and does the same thing. I use pea size lava rock, though.
Shine on you crazy diamond."
- ScotsPagan
Thanks all;
I'll aim for 1-1.2m for the "main column", given the t-junction and R-condensor will likely add on 30-50cm, and that will be into ladder & scraping ceiling territory...
Anyone any tips/preferences for the product condenser? Shotgun vs. Liebig etc.
Started modelling the beast in 3D here so I can think about cable routing, sensor positioning etc.
If only it was this easy in real life. I need Iron-Man's "OK, design done, print & make this while I get coffee" thing...
A liebig will be fine.
- ScotsPagan
I put the pic in the "my first" forum where I've got a thread, but I suppose this is actually more appropriate here...
For my comments on the design, nice graphics by the way, the 100mm section for a gin botenicals, you can’t run in line like that, you will end up with brown distillate, take a look at a carter head, this will sort this out, you will have botanicals stink your column out in this configuration and you will have brown gin.
Cheers
Tony
Cheers
Tony
- ScotsPagan
Ahhh! Thanks, I'd gotten confused as to the layout of the gin-head. So I want them at the very bottom or top of the column rather than in-line on the horizontal? Gotchya...
At the top of your still column the vapour will condense on your botanicals and drop this down your column, this will stink your still out, at the bottom of the column well not that efficient, you might as well steep the botanicals in the boiler and it will still stink the column, check out a carter head.
Here’s a picture of my version, it has a tap at the bottom to drain what condensed to much, a perforated tube sits in the top 2 sections that hangs in there full of botanicals. I can remove mid run by fully refluxing the column to add or change the botanicals. It’s offset to the still column so nothing drips in to the column.
Cheers
Tony
Cheers
Tony
