Reflux column on a thumper
VM CM LM Flutes Plate
Postby Alchemist75 » Tue Jan 15, 2019 12:50 pm
Searching I came across this:
viewtopic.php?f=15&t=48453
Which depicts a design featuring a reflux column mounted on a thumper. It got my attention simply because it could help me with my current clearance problem. Bigbird never posted a follow up on how the thing really worked out though he appeared optimistic. Has anyone worked with a similar design that could talk about it? Theory is welcome of course but any hands on would be the most helpful here. Your input on this concept is welcome! I'm very curious....
SOLVE ET COAGULA, ET HABEBIS MAGISTERIUM
Alchemist75
Re: Reflux column on a thumper
Postby still_stirrin » Tue Jan 15, 2019 1:32 pm
It works just like a reflux column that is directly mounted to a boiler...except that the vapors are plumbed into the thumper instead of "produced" there. The reflux system works just like it would on a boiler, condensing and purifying the rising vapors while the falling condensate accumulates in the vessel below the column. Ba-da-bing!
What is a Proof & Traille hydrometer: Alcohol-meter
Enzyme info: SebStar
HD Google search info: HD Google-how to
All about mashing grains: Braukaiser
Master Distiller
Postby Alchemist75 » Tue Jan 15, 2019 1:45 pm
Thanks still! You're opinion is always useful. I forsee a flurry of building in my near future....
Alchemist75
Postby Kareltje » Tue Jan 15, 2019 4:03 pm
I sometimes use my spiral riser on my thumper. This riser reacts more or less like a reflux column and the effect is just like stillstirring says.
In fact a thumper is just a boiler, heated by incoming vapour in stead of gas or electricity and also fed by incoming vapour with both alcohol and water (and taste).
Kareltje
Postby Alchemist75 » Tue Jan 15, 2019 5:48 pm
By my estimate a set up like that would give me a total of 8 theoretical plates at high reflux. I'd probably run it a bit less tight than 8 though so likely closer to 6.5-7 which is perfect, I like flavor retention.
Alchemist75
Postby Smeg » Wed Jan 16, 2019 3:06 am
Build it and run it,,, all the theory is just theory. Theory is just a guide, there are always variables in practice.
You wont know till you try.
Smeg
Postby Yummyrum » Wed Jan 16, 2019 3:41 am
Stuck my flute on my thumper . viewtopic.php?f=16&t=59918#p7388267
Worked but were issues with flooding on the bottom plate . In hind sight I was probably running it too hard .
In another attempt I tried using the boiler as a steam generater and the wash in the thumper ( was using the 80 liter keg as thumper and 50 liter for steam)
But boiled the 50 liter dry .
Things to be aware of. .... in reflux mode , there will be a substantial buildup of liquid in the thumper cmpared to using a pot head on it .
Due to the extended runing time ( due to refluxing) , the liquid in the boiler my boil dry if not carefully planned .
An overflow from the thumper back to the boiler is a cunning plan as are sight glasses in each otherwise
Apart from that it work well :thumbup: reflux columns love a high avb under them :D
Postby Alchemist75 » Wed Jan 16, 2019 8:18 am
I'd think you'd want to start with an empty thumper, hold the column at full reflux until you start getting audible activity in said thumper and then begin taking off the first bits. The thumper is surely just another plate in the column to be loaded in the usual way. Maybe I'm mistaken about that idea.
Coming up with some sort of return line might be a hair tricky, seems like it'd need a valve of some sort.
Alchemist75
Postby Alchemist75 » Wed Jan 16, 2019 8:33 am
Return line aside, the thumper volume would need to be at least as big as the charge in the boiler itself, probably a bit bigger.
Alchemist75
Return to Column Builds
Who is online
