Offset head style
VM CM LM Flutes Plate
Offset head style
Postby Bavis54 » Thu Jan 17, 2019 7:03 pm
Hi friends, I’m trying to find some plans and decide on what type of column to start with, I ran across some plans for offset head type columns on parent site. Has anyone ever ran one these? If so what’s you think? I can actually understand n follow these- I just wondered how they perform.
semper fi
Bavis54
Re: Offset head style
Postby bluefish_dist » Fri Jan 18, 2019 7:02 am
I do run an offset style vm. I found a design I liked that used two valves with a T and then removed one valve. It looks like a Nixon stone offset, but has a vm out the other side. I am not a fan of the lm side. The valve is not sesponsive enough to have good control. Also as it’s a lm the normal decreasing reflux makes it a little less easy to run than the vm side.
The advantage is that it can be made with a minimum of welding. On my 4” T head the only welding was a single return line into the column. The rest is off the shelf parts.
Formerly
Dsp-CO-20051
bluefish_dist
Postby still_stirrin » Fri Jan 18, 2019 7:25 am
Bavis54 wrote:...I’m trying to find some plans and decide on what type of column to start with...
Here’s a thread: viewtopic.php?t=1109#p13331
Nixon-Stone
What is a Proof & Traille hydrometer: Alcohol-meter
Enzyme info: SebStar
HD Google search info: HD Google-how to
All about mashing grains: Braukaiser
Master Distiller
Return to Column Builds
Who is online
Users browsing this forum: HBsmam and 3 guests
