I’ve been thinking about enhancing my mini gin still so that it can also function as a vacuum still for low temp essential oil extraction. I want this to be an attachment module rather than a dedicated use still, so that I can remove all the vacuum components when I just want to run my mini as a simple pot or gin head still.
There are two big challenges I know I will have with this still.
The first is making this still vacuum tight. My desire for a modular design means I will have lots of temporary (union) and semi-permanent (threaded) joints. It’s hard enough making permanent components air tight, let alone threaded and union joints. I plan to start with simple/quick copper union connections and will address any vacuum loss issues as they arise. I also know from experience that the factory ferrule on my keg boiler does not always get the best seal, so that’s another point I will need to watch when attempting to maintain vacuum.
The second challenge I may have is maintaining a consistent vacuum level when distilling. I need the vacuum level consistent so that the boiling temp will also remain consistent. I think that the small volume of my mini-boiler and collection tank mean that pressure changes will come quick and be a challenge to hold steady. I will start this build with just the bare minimum components needed for the still and if this concern is realized, I have a plan B to address it. Plan B: If I can’t maintain a steady vacuum level during operation, and it’s not due to a vacuum leak, I will try adding a large buffer vacuum tank to the system.
Collection Tank
I decided to start my build by creating the collection tank. I started here because I thought this would be the toughest and most costly component of the still. After several roughed out plans I landed on a plan to use all purchased parts, no welding required.
I’m using a 3” stainless steel Tee as the tank. The useful capacity of this tank is ~1 liter.
* The center of the tee faces up, and has a 3” cap with 1/2” threads to accept collection input.
* One end of the Tee has a 3” process view sight glass that functions as the collection gauge, so I can see the amount collected from beginning to end.
* The other end of the tee is capped. This is my expansion port. If I need a larger collection tank I simply add a spool to the back end. An 8” spool would add another liter capacity to the tank. I used two 3” pipe standoff’s and a few bits of wood to make a stable base for the tank. A big part of my decision to using these purchased parts as the tank is that I can also use them on other distillation equipment I run. That 3” Tee can be added above my 3” packed column using the 3” process view sight glass on the side.
More work to follow
Otis
