Rubber/Road CCVM vs Tube Dephlegmator
tiramisu
Post by tiramisu » Tue Mar 09, 2021 11:46 am
Reflux condenser...
So I can get me a 3" 200mm - 9 pipe (12mm od) dephlegmator in copper for 145USD
OR
For about the same price that I can twist up a 3/8 CCVM copper coil and glue the parts together.
The decision was much easier when CCVM was clearly the cheapest and easiest solution.
Now apparently I am required to think. Always a bad idea and I try to avoid it.
Are there any clear advantages to a tube dephlegmator over the ccvm? (other than I can avoid labour)
It looks tidier but I suspect it is less easily/quickly adjusted.
Any efficiency advantages in cooling?
The darn thing is pretty and would save me a bunch of fabrication but I'm not sure that which way to kick.
Any thoughts?
thanks,
t.
