After a year I'm finally going to complete my ccvm, ?
It's been about a year since I've started this project and I never got around to finishing the reflux column. This is a modular build with tri clamps and I have a question. For the ccvm column it is going to be 2 in by 40 in Long. What would be the advantages or disadvantages of cutting that column down to two 20 in sections? I guess the thing i want to find out is will the joint in the middle of the column affect how it operates in a negative way ? I'm running a half barrel keg and soon will be upgrading to a 5500 watt heating element.
- Deplorable
Re: After a year I'm finally going to complete my ccvm, ?
My 2" CCVM consists of two spools below the sight glass and T. I pack it with rolled copper mesh and the joint in the middle doesnt create any problems.
I see no disadvantage to a joint in the middle other than the $20 or so it'll cost you for the ferrules clamp and gasket assuming you're cutting a copper stick to build from.
As far as advantages, it's easier to pack away a couple short spools than it is to pack away a nearly 4' long peice.
Thanks for the reply and as long as there's not going to be any ill effects I'm going to cut it in half. The only thing I'll need to order is ferrules. I've already got all of the tri clamps and gaskets that I need because my pot still was set up into sections as well.
The joint won’t be any problem. My 2” CCVM column has 2 x 600mm spool sections
Modular 2" Pot Still
