CM the benefits and the downsides
- Stonecutter
Running my CM reflux still tuned down to a mere trickle while maintaining a decent takeoff rate (about 3-4 drops per second) results in a fairly flavorful whiskey with high abv 80%. To me that’s beneficial. The down side is that it’s a one and done run using reflux so you don’t have as much product in the end of your final run and you lose a bit of flavor. Anyone else out there experimenting with this setup?
-Thomas Paine
-Thomas Paine
Re: CM the benefits and the downsides
I have a 4” diameter CM and I run it a bit faster and feel I get good flavor. Not sure I understand your downside, as I don’t think I would get a smaller amount of useable alcohol on my CM as opposed to a pot still?
There's many of us running CM stills.
It's the most versatile and my favorite.
The Pro and Con of CM is it's controllability.
A CM works best with constant heat, such as electric.
It also works best when the cooling water temp is constant.
posting with Bushman
- Stonecutter
I’ll turn my reflux pump on late into my heads and turn off 3/4 of the way through hearts. That way I can gather that much more flavor towards the end and really make tight cuts into my tails.
Yes it was a pretty piss poor example of a “downside”. Was hoping someone could come up with something better
I absolutely agree. I keep my reflux/Liebig water supply between 78-81 degrees throughout the run. I use a 110V 2000W electric element. If I keep that throttled to 50V I can go through 90% of my run without touching the SSR.
-Thomas Paine
-Thomas Paine
- Stonecutter
I’ve never run a CCVM which is a really popular design. Why do you guys think CCVM seems to get more attention than CM? Is it because of build-ability?
-Thomas Paine
-Thomas Paine
- Windy City
What is the diameter of your cm still that you are just getting drips.
I get about 1.75 liters every 12 minutes or 8.75 liters per hour from my 4” CM
- Windy City
Is it bubble cap, perf plates or a packed column
Why would you have the reflux off in the beginning.
That is when you are trying to compress heads.
If it is bubble caps or perf plates how many?
Flavor will come through plates (cap or perf) very well.
Don’t turn off the reflux, that is one of the things a CM does well is shutting itself down for tails
- Stonecutter
I’m at 2” (par for the course in my life in general ) if I run any faster I’ll start to flood a bit. Column packed with 2 rolls of copper mesh each about 18” long. I’ve been thinking I could probably pack a bunch more copper in there.
-Thomas Paine
-Thomas Paine
- Stonecutter
It’s nothing more than a reflux jacket sitting on top of my riser below my Liebig.
-Thomas Paine
-Thomas Paine
- bluefish_dist
Easy to build, easy to run. The favorite used to be a boka for the same reason, but the CCVM is even easier to build.Stonecutter wrote: ↑Thu Jun 03, 2021 7:47 pm I’ve never run a CCVM which is a really popular design. Why do you guys think CCVM seems to get more attention than CM? Is it because of build-ability?
Formerly
Dsp-CO-20051
Dsp-CO-20051
What puts me off building a plater, is the thought of doing cuts on every boiler charge. For four charges, the plater requires four sets of cuts. For four charges with a pot, you have to add on a fifth run, but that run produces four times the product to choose your cut from and the stripping runs for a four times larger ferment are fast and require little brain power after the first one.
I've just put down a wash of free fruit that is about 7 charges worth of wine, so 7 runs with cuts for a plater, or 7 fast stripping runs with my Charentaise style preheater setup, (which I should be able to do in a day), then two sets of spirit runs and cuts.
YesStonecutter wrote: ↑Thu Jun 03, 2021 7:47 pm I’ve never run a CCVM which is a really popular design. Why do you guys think CCVM seems to get more attention than CM? Is it because of build-ability?
Pros:
Cheap and easy to build.
Quick to learn to operate.
Not as finicky about fluctuations in water supply as a CM.
In most cases won’t require a needle valve for fine scale control of coolant flow.
You get nearly an instant response to changes of the position of the reflux condenser.
You can usually get away with plumbing the product and reflux condensers in series
You won’t need a valve like the VM has.
Conversely:
They can be a bit tall with the RC above the offtake.
I need to stand on a stool to change the position of the RC.
You need to use a flexible plumbing solution for putting the RC at different heights.
Tricky to make a mechanical remote or automatic RC position adjuster
I find it boring to operate so I only do one (BIG) run a year
Have I missed anything?
Modular 2" Pot Still
- Stonecutter
Are water supply fluctuations really that common? I think most guys are running radiators with fans and a pump for cooling. Guys running smaller rugs can manage with a cooler and some ice with a thermometer. Sure, you need to basically feed ice every 5-10 minutes which can be a pain but it’s do-able. I would assume a needle valve would be beneficial no matter what kind of reflux design your running.kimbodious wrote: ↑Thu Jun 03, 2021 11:48 pm
-Thomas Paine
-Thomas Paine
Water supply fluctuations are an issue for people running CM stills using tap water for their coolant.
There's one thing a CM can do, that other reflux stills can't.
A CM can run at lower reflux ratios. That gives it a real advantage when making whiskey.
This thread is a bit confusing because it is combining a CM packed column and a CM plated to aquire the same results. Both CM but desired end results are not the same. Plated CM is best for the tasty stuff one and done. Packed CM is for natural or voddie stuff. When talking CM end product decides what column to use.
- Stonecutter
I guess it’s Ford vs Chevy debate between CM and VM regarding neutrals? And the consensus for flavors is on the plated CM side?
-Thomas Paine
-Thomas Paine
In theory you could / can use either sort for either job.......in reality one is the right tool for the job at hand , the other is not.Stonecutter wrote: ↑Sat Jun 05, 2021 3:17 pm I guess it’s Ford vs Chevy debate between CM and VM regarding neutrals? And the consensus for flavors is on the plated CM side?
Trying to use the wrong one for the wrong job, just makes your life more difficult. Using the right tool for the right job makes it a breeze.
There are a ton of posts here on the forum written years ago about making whisky and such using detuned packed columns if you want to go down that rabbit hole.
I've noticed 99% of the plated columns use a CM head.
Just guessing, a VM, CCVM or LM head can't be turned down like a CM.
A plated column needs enough reflux to keep the plates loaded but much more and flooding becomes a problem.
A CM is able to turn down enough to do that. The other options except for an offset LM can't.
But compared to a CM, an Offset LM would have more smearing.
Or so my alcohol persevered brain is telling me.
On a side note.
I don't think it matters what type of reflux head is used on a packed column.
Mostly packed columns are used for something like vodka or neutral.
Where high reflux ratios are the norm. An example for a 10:1 reflux ratio.
100% of the vapor goes up, 90% rains down as reflux and 10% goes in the jug.
On a side note.
Not sure what you mean Shady . I have VM head on my 4” perfplate . Works just fine . Also works when I stick it on 2m x 4” packed .
Shady, myself runs plates with CCVM heads. i must tun very hard on propane to get a flood. on electric with a 3.6 KW heater it does not flood but i run around 3 KW on a 1.5 charge.
to Chris, these days i strip a charge on pot still and the combine it with mash for a full charge. it nets double of a single charge with good flavour.
My first flute
My press
My twins
My controller
My press
My twins
My controller
That makes a lot of sense. Extra esters because of the acids in the mash reacting with the higher abv from the strip.
i never thought of it that way, thanks for the headsup on the esters.
My first flute
My press
My twins
My controller
My press
My twins
My controller
Ive done it that way to for a long time with my Rum Setsumi, ...sometimes I do UJSSM that way to..other times I single run it, all of the Uj however its run ends up in the same barrel....the blend seems to work for my taste buds.
I used a pressure reducer made for RV to keep an even and slightly lower water pressure so flow doesn’t vary with my well pressure. Not so much of an issue now, but I used to have a faucet that came off my well line before my pressure tank and when pump would kick on it seriously increased pressure and flow...kimbodious wrote: ↑Sat Jun 05, 2021 12:25 pm Water supply fluctuations are an issue for people running CM stills using tap water for their coolant.
- bluefish_dist
Honestly I think the reason cm’s are so common is they scale the best. Ie much easier to make bigger. Because of this, that’s the type of head used for commercial distillers. It’s also easy to make if you are selling stills and have the capability to make a shotgun condenser. Yes, they can run lower reflux rates than a VM, but I made a 1:1 VM and never ran it even close to 1:1. Couldn’t control the abv like I wanted. The lowest reflux I would usually run was 4:1 and even that only lasted for a small portion of the run, maybe 10%. Usually I was 4-5 turns open out of 20.shadylane wrote: ↑Sat Jun 05, 2021 4:21 pm I've noticed 99% of the plated columns use a CM head.
On a side note.
Formerly
Dsp-CO-20051
Dsp-CO-20051
- Stonecutter
After gaining more experience and understanding of my equipment my processes have changed. I now compress my heads to varying degrees based on what’s in the boiler. For instance, as an experiment, I ran a brandy last week and didn’t compress my heads as much in the hopes that I could drag more flavor out of them. Maybe there’s a better way of doing this? I’ve got a mesh “trap” on the bottom of my sight glass that sits just below my reflux chamber. I add about one inch of rashing rings there and it acts like a small plate. I have two bundles of copper stuffed into my column below that. As SSB explained there is a rabbit hole for hobbyists that run tuned down reflux rigs and I can see myself naturally heading that way.Windy City wrote: ↑Thu Jun 03, 2021 7:58 pm Is it bubble cap, perf plates or a packed column
I’m definitely running faster now with better results. It’s exciting to make those small steps towards becoming a decent hobbyist. I’ve got a long way to go yet and I appreciate everyone’s input.Windy City wrote: ↑Thu Jun 03, 2021 7:52 pm What is the diameter of your cm still that you are just getting drips.
-Thomas Paine
-Thomas Paine
