Bended copper is dangerous?
Hello, I finish my first run, but when i was taking off the screws I accidentally bended the copper from the still , do you think is dangerous if I used like this?
Re: Bended copper is dangerous?
It looks like it is significantly restricting the flow. That is a bad thing. Where it is near the end and you can get a straight shot at the twisted part you can probably heat it and get a rod pushed in from the end to reform it.
All rigth, thank you so much for your answers!
- jonnys_spirit
This happened to my first liebig and it worked but not optimal so I eventually replaced it with a DIY. Should be easy to cut and re-solder an extension. Is that a 1/4" worm?
Cheers,
j
Cheers,
j
Yeah, it's a 1/4 worm, just did a vinegar run for cleaning up and it worked fine, if I see something weird going on, definitely gonna resolder it. Thanks!
Picture is a twisted flare joint connection. What the hell, cut it off and re-flair it, no soldering or cleaning required. Now you know why a backing wrench is required on flair joints.
Personally preference but i would not go below 1/2 inch anywhere on a still. To easy to block. Blockage = very bad .
Anything open to the world you should blow through before use.
Insects love to get in there.
- squigglefunk
that's a weird condenser for a column eh? But yeah I would not use that as is!
