Vacuum Relief Valve vs Check Valve?
Fittings,,,Parrots, Packing., Tooling.
Postby DAD300 » Thu Dec 07, 2017 6:47 pm
I am wondering what the engineers here think about this idea.
VRV's are expensive, say $80usd or more. They open at a set pressure (for a boiler 1-5PSI) to prevent negative pressure in a boiler or steam jacket while cooling, preventing collapsing the vessel. They also chatter when in use. And you never really know if they are stuck or not.
VRV
VRV r.jpg (1.29 KiB) Viewed 181 times
Why shouldn't I replace a VRV in a design with a Check Valve that costs $5usd? The Check Valve opens at any minimal negative pressure, preventing collapse. The cost dif and availability is crazy as every big box store has these. And you can always poke the opening to see if it is stuck!
Check Valve r.jpg (37.99 KiB) Viewed 181 times
Basically, the price dif makes me ask!
DAD300
Master Distiller
Re: Vacuum Relief Valve vs Check Valve?
Postby RedwoodHillBilly » Thu Dec 07, 2017 8:03 pm
GodDamnit, you always come up with what is an obvious solution to a problem (obvious after it's explained to me). I use a PRV/VRV like you show in your 1st pic. But when you think about it, what is the VRV part but a check valve set to about 1/2 PSI. My question is what pressure will the check valve/VRV pop off at?
John Barleycorn must die.
"and little Sir John in the nut brown bowl proved the strongest man at last.
The huntsman he can't hunt the fox, nor so loudly to blow his horn
and the tinker he can't mend kettle nor pots without a little barleycorn."
RedwoodHillBilly
Return to Still Related Hardware
Who is online
Users browsing this forum: No registered users and 2 guests
