Has anyone ever experimented with a bobber-type SG indicator? I’m thinking about building one, that will sink automatically around 1.01 FG. If used with a clear plastic cover for the fermenter, it would provide an instant, and perhaps even gradual, indication of current SG.
Of course, the weight of such a bobber would depend on the size. I was just wondering if anyone had done it. I wasn’t able to find any in a search, either here or on the Internet. An experiment, to be sure!
Alcoholmeter
Re: Alcoholmeter
- The Doubler
Run it, X. Thump it, XX. If you get 1.5, well, I think you can do better!
It's EASY to make good liquor. It's even EASIER to make bad liquor!
Re: Alcoholmeter
A standard hydrometer will float in a wash no problem, no doing needed there. The problem is that with most washes/mashes bubbles and floating material will mess up the reading. So you end up having to pull the hydrometer and sample to get a clear reading.wpkluck wrote: ↑Tue Feb 23, 2021 1:17 pmHas anyone ever experimented with a bobber-type SG indicator? I’m thinking about building one, that will sink automatically around 1.01 FG. If used with a clear plastic cover for the fermenter, it would provide an instant, and perhaps even gradual, indication of current SG.
Og course many will say, it's just not needed. Wait until it slows down then taste it, and feel if it's sticky on your fingers.
_____________________
EXPAT
Current boiler and pot head viewtopic.php?f=50&t=71855
Cross flow condenser viewtopic.php?f=87&t=47632
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
Re: Alcoholmeter
Thanks, Expat. I have a std hydrometer, and of course it works fine. But I have to take the top off my bucket to check. I’m trying to think of a way to have a visual indicator. Like a bobber on the lake, when it goes down, the mash is done.Expat wrote: ↑Tue Feb 23, 2021 3:38 pmA standard hydrometer will float in a wash no problem, no doing needed there. The problem is that with most washes/mashes bubbles and floating material will mess up the reading. So you end up having to pull the hydrometer and sample to get a clear reading.
- The Doubler
