Minimum size still for a Parrot?
Being an engineer I am prone to overthinking so i calculated out the volume of a parrot at about 6-8oz. If I have a 8 gal still running 5 gal batches and 3/4-1 gal total output would a parrot be all that helpful? I am running 8-16 oz cuts right now so it seems likely not... if I had a 15 gal still then sure... but then I am running reflux. Maybe a pot still should be run differently.
what say you?
Thanks.
what say you?
Thanks.
Re: Minimum size still for a Parrot?
I don’t have a parrot.
I collect in small jars and measure the proof of the jar. Then I put a piece of masking tape on the jar and write the jar number (in the collection series), the date run, and the measured proof. Then, I cover the jar with a coffee filter and wait 24 to 36 hours to sit down and figure my cuts. Regardless of running a strip run, a potstill run, or a reflux run, I haven’t needed a parrot to make liquor.
Oh, and by the way, I’m a mechanical engineer too.
+1 still_stirrin
I don't go labelling the jars but do check ABV of each when I change jars .
If I'm doing a stripping run I might stick a measuring cylinder under the spout when I'm getting close to done just to see where I'm at .
Never needed a Parrot. But I see your question is probably about smearing in a parrot relative to the amount you collect .
To be honest if you are talking a Pot still here , there will be more smearing happening simply because its a pot still than the parrot will cause .
6-8 oz does sound a lot of volume for a parrot though . thats about 175-235 mls for us metric folk .
On a spirit Run I'd normally want about 20 jars so I can make reasonably good cuts .
3/4-1 gal is 2.8 -3.8 liters so I'd be wanting to collect 140-190 mls per jar . Looking at it that way , your parrot is relatively large . Perhaps you could get a smaller hydrometer for on the fly parrot work and keep your big ( more accurate ) one for proofing . That way you could signoficantly reduce the volume of your parot to probably around 100mls
Thanks guys,
I have not finished the design of the parrot yet. Looks like I need to go with a 1/4” diameter tubing on the upstream side of the meter to cut down on the volume and then I will be ok. Before it was all 3/4.
Lots of fun. Lots of opportunity.
I like a parrot but I a. Doing 11 gallon runs in my keg. Before having a parrot I did the same thing, got tired of measuring the abv in each jar. I now feel my smell, feel, and taste has improved through experience and knowing my run cuts are a lot easier thus I am able to collect in larger jars.
Be aware Mike that with parrots you trade getting immediate ABV knowledge with "smearing."
That is, your collection pools into the parrot and makes cuts harder to distinguish. That's why you don't see too many people using them.
Just a word to the wise.
Your still is plenty large enough for one though. But I'm concerned the 1/4" upstream (from the still) risks blockage.
Flow is still slow enough through 3/4" to remain practical. Please consider safety.
- jonnys_spirit
If you use or make an inline parrot with an empty-it-valve then you can collect about 200ml or whatever you want and empty it so the smearing is limited to what it will be for a 200ml collection anyway - it just makes less steps to complete. It's just a reference measurement anyway.
-j
-j
+1 to Still_stirrin, though I don't bother with checking ABV per jar. Unless I am on new equipment I figure it is what it is. I do check the last jar to ensure I have run things down far enough. I do check ABV after making cuts so I know how to dilute.
I see more value in a parrot if you are running a large volume boiler and already know your recipe/process, like you may see at a micro-distillery.
Otis
Otis
i put the outlet into the test jar. let it fill up till there's enough to test proof. dump that in the collection jar and repeat as i see fit
I collect in jars like most but don't even check ABV until I know I'm close to the end of the run. After airing out and making my cuts I check the ABV then for diluting but that's it.
Swedish Pride wrote:
I collect in numbered jars. 100 ml if I want to as accurate as possible (my glass cilinder for my alcoholmeter is 100 ml) and up to 500 ml for the larger parts.
I have two 10 l boilers, sometimes coupled as boiler and thumper.
I also have a 80 l still, but I use that only for stripping 60 l birdwatchers. Then I use 500 ml for accuracy and 5 l for larger, stable parts.
Until now I have seen no use for a parrot.
To judge the end of a run I use a thermometer, and an alcoholmeter to confirm.
