Soldering/welding stock pot lid
Hola amigos!
I'm planning to build a new pot still, a big one. The boiler should be 200L capacity made with a stock pot still like this one: My idea is instead of sealing the lid with gasket and clips I would like to solder the lid. Probably tin/siver solder and a good flux like Stay-Clean would be enough.
It is for a 4" pot still so the soldering should be strong.
I've soldered small SS pieces like couplers succesfully in this way.
What do you think? Am I planning something absurd or it could work?
I'm asking because i tried to look for someone soldering a lid and i didn't find it.
Thanks a lot in advance
Re: Soldering/welding stock pot lid
I soldered two kegs together once, worked fine.
- Swedish Pride
downgrade your stock pot to 100l as thats the upper limit that's allowed to be discussed here.
If you're just to use it as a pot still 4" is way overkill, 2" is more than ample for your needs, Also I'm not sure id trust the lid with the weight of a 4" pipe.
Soldering the lid is easy, get a good flux like harris stay clean and get a 150w soldering iron off ebay and you're golden, normal lead free solder is sufficient.
Don't be a dick
Thank you very much for your answers.
I'm assuming that the whole diameter soldered will be strong enough or I hope so.
Actually the small joint like these are surprisingly strong. I made a couple with my inline thumper that holds all the weight of the column and cooling lines easily.
I would also question why you would want to solder the lid and use 4 inch for a pot still? How will you connect the column to the lid?
By being able to remove the lid you can easily access the inside for cleaning. I use an inverted bowl with a large reducer soldered
on to it and it supports a tall marble packed column which is quite heavy. I secure it with the typical binder clips. I would just solder
on a 4 inch ferrule if you are determined to use 4 inch.
Hi ben stiller! My idea is to use a pot with a big diameter so I won't be able to find a bowl with such diameter, although I like very much the idea.
Anyway many of us use kegs. My soldered stock pot could work like a keg but with a 4" hole so with a pressure hose or even with my hand and a scrubber I will be able to clean it. At the bottom of the pot there will be a draining ball valve...
I want to solder the lid because it will hold the 4" column, a separate gin basket and a dimroth condenser attached at the side. The weight will be focused on one side...not on the center.
My plan to support the column is tu use a SS ferrule soldered on the center of the lid with the flange facing up.
If the lid is flat maybe consider putting the ferrule off center to help balance the off center weight of the gin basket and condenser.
That's a great idea ben... thanks a lot for your advice
This is the plan
This is the plan
Why not just extend the product condenser to the other side of the column. That should off set the wieght.sergiolis wrote:That's a great idea ben... thanks a lot for your advice
This is the plan
AC
