Teflon 2" Tri-Clamp Gaskets
The other thread talking about safety is LOCKED,
but I wanted to come clean the HD way and proclaim my new acquisition.
Ten PTFE (Teflon) 2" gaskets for $8
They even have the raised ring in the middle like the silicone ones I had.
I'm now up to speed with the PTFE gaskets and natural cork topper instead of gum.
Not to mention all stainless steel funnels and glass jars.
- ShineonCrazyDiamond
Re: Teflon 2" Tri-Clamp Gaskets
Rub one side of one on a piece of 120 sand paper for 30-45 seconds. And you will have a perfectly flush side to butt to your keg, and the other will have the lip for the ferrule.
Shine on you crazy diamond."
Thanks, SoCD. But I've got ferrules from top to bottom, and all the gaskets have a raised ring on both sides.ShineonCrazyDiamond wrote:Rub one side of one on a piece of 120 sand paper for 30-45 seconds. And you will have a perfectly flush side to butt to your keg, and the other will have the lip for the ferrule.
But that info will be stored for my NEXT still...
Always appreciate your input.
- jimmayhugh
Or just buy this oneShineonCrazyDiamond wrote:Rub one side of one on a piece of 120 sand paper for 30-45 seconds. And you will have a perfectly flush side to butt to your keg, and the other will have the lip for the ferrule.
$.80 vs. $4.00, though...jimmayhugh wrote:Or just buy this oneShineonCrazyDiamond wrote:Rub one side of one on a piece of 120 sand paper for 30-45 seconds. And you will have a perfectly flush side to butt to your keg, and the other will have the lip for the ferrule.
Also, I'm going to post this here. I was going to in the last thread before it turned to silicone again. But every generation of stillers should be aware...
S-Cackalacky wrote:I've been using these - http://www.usplastic.com/catalog/item.a ... &catid=720" onclick="window.open(this.href);return false;" rel="nofollow . The 2.725" size fits a regular mason jar and the 3.5" size fits a large mouth mason jar.
I use these for aging on glass - http://www.widgetco.com/jar-cork-stoppers-standard" onclick="window.open(this.href);return false;" rel="nofollow . The 3.5" (size 48) fits a 1 gallon large mouth pickle jar.
...and I thought I was done...ShineonCrazyDiamond wrote:Also, I'm going to post this here. I was going to in the last thread before it turned to silicone again. But every generation of stillers should be aware...
You bastard
Well, lol. We're never done, haha. But I just replace the mason jar lid with these, and screw the band on. Ptfe, and when aging in the attic the heat expansion lets angel share out, and protects from jar explosion.
- jimmayhugh
To me, the few extra dollars is worth the peace of mind, and you only need one.ShineonCrazyDiamond wrote:$.80 vs. $4.00, though...jimmayhugh wrote:Or just buy this oneShineonCrazyDiamond wrote:Rub one side of one on a piece of 120 sand paper for 30-45 seconds. And you will have a perfectly flush side to butt to your keg, and the other will have the lip for the ferrule.
