I had been hoping to avoid a drastic reduction in takeoff diameter and go more gradually. For my 2" CCVM column build I had been planning on a 2" takeoff and elbow and building a 3/4 x 1/2" Liebig for the product condenser. With a (planned) 2" to 1" concentric reducer, I thought it'd be straightforward to get a 1" sanitary to 1/2" MNPT fitting and be good to compression-fitting from there onto the Liebig.
BUT, I am having a devil of a time finding 1" sanitary to 1/2" NPT fittings. All the "to .5" NPT" options seem to be in 1.5" sanitary instead. OK, well and good, but would the pool formed from the larger "stop" where 1.5" reduces to a .5" to the Liebig pose a problem?
Reducing gradually (less smearing) to PC?
Happy bees, home brews, and two green thumbs.
Re: Reducing gradually (less smearing) to PC?
Ya looking for something like this
https://www.amazon.com/Dixon-B23BMP-G10 ... T+fittings" onclick="window.open(this.href);return false;" rel="nofollow
I'm not sure, but I think a 1-1/2 and a 1" use the same clamp and can be connected together
I don’t think you will have any pooling issues worth worrying about .There will be hundred times more smearing happening in your cuts jars.
Yes exactly like that. But how does 1" and 1.5" for the same clamp? I saw several products making that claim.shadylane wrote:Ya looking for something like this
Damned if I knowBenredbeard wrote: But how does 1" and 1.5" for the same clamp? I saw several products making that claim.
I've got 3/4" and 1/2" with the 1.5" ferrule clamp and gasket.
- Oldvine Zin
1" and 1.5" have the same size outer dimensions for the tri clamp they are interchangeable just the inner dimension is different
OVZ
OVZ
