Is there a liquid Teflon somewhere
BoomTown
Post by BoomTown »
I’m needing to make me a new gasket for the lids of my stills. If there were a tube of Teflon caulking that dries in place, that would be excellent solution for me.
Anyone know of such a product?
bcook608
Re: Is there a liquid Teflon somewhere
Post by bcook608 »
That's what I used for mine and it's working quite well
bcook608
Post by bcook608 »
This one has different sizes and thicknesses.
It's really nice and fat and relatively soft so when you initially clamp your lid down, it forms nicely to the body of your boiler and stays that shape.
BoomTown
Post by BoomTown »
bcook608 wrote: Thu Jun 23, 2022 9:17 pm
Thanks, just ordered some. It’s exactly what I need!
greggn
Post by greggn »
That's adhesive-backed, right ? At the very least, I'd soak that in heads for a few days to remove the adhesive before use.
________________
greggn wrote: Fri Jun 24, 2022 8:04 am… That's adhesive-backed, right ?
No. It “stretches” and will “stick” to itself. It’s “plumber’s tape”, used to “lubricate” pipe joints to allow them to be tightened without galling between the threads. No adhesive, just a soft, flexible teflon “tape”.
greggn wrote: Fri Jun 24, 2022 8:04 am… At the very least, I'd soak that in heads for a few days to remove the adhesive before use.
Boomtown - FYI: No need for this. Just wrap it around the edge of your boil pot, slightly stretching it tight. It’s tricky, no doubt. But, it can be done. This is exactly how I put the seal on my stock pot potstill.
greggn
Post by greggn »
still_stirrin wrote: Fri Jun 24, 2022 8:12 am No adhesive, just a soft, flexible teflon “tape”.
The $42 one has a description of ...
Expanded PTFE sealant tape is a multi-purpose gasket tape manufactured from 100% expanded PTFE fluorocarbon material, supplied as a continuous low density tape with a self-adhesive backing strip.
The $37 one has a curiously worded usage statement ...
Usage method
Take a piece of tape of arbitrary length, paste it on the sealing surface (itself with glue) as long as the two ends overlap each other, you can form a gasket.
... because the "itself with glue" phrase seems to correlate with the expanded view showing a line of backing tape.
________________
I have heard that expanded PTFE is OK as long as it's for a one off application. PTFE has little 'memory', so if you have a wonky lid to seal, you must position it exactly the same way every time, or use a new strip.
