Where do you feed your Parrot
A question for all of you parrot beak users, I made my parrots beak with 3/4 copper to take a 5/8 dia alcometer, the feed to the 3/4 is at the bottom of the pipe. I notice while doing a run, that the alcometer reads 20ABV lower, when I stop the feed to the parrot beak and let the alcometer settle, it settles to the higher reading. This is obviously getting a hydrolic affect from the alcohol feed.
If I feed the parrot beak from half way instead of the bottom do you think this may overcome the problem.
Where does the alcohol enter your parrots beak? Half way down or at the bottom?.
Re: Where do you feed your Parrot
I feed a one inch parrot at the bottom, I likely don't get as much "lift" in the one inch pipe as you are getting in the 3/4, I've never noticed it settle more than a hair when the flow stops.
same here but i have about a 2% dropUgly wrote:I feed a one inch parrot at the bottom, I likely don't get as much "lift" in the one inch pipe as you are getting in the 3/4, I've never noticed it settle more than a hair when the flow stops.
Some people say its "FREE" but i say "there ant no free lunch" you get what you pay/work for
help those that help them self first
25Lt old school SS keg as a pot with a prototype Ponu still head
I don't worry about it. What's a couple of % points?
Cumudgeon and loving it.
A parrot is NOT used to make numerical readings. its merit is to display changes in your output to give you a hint as to where you are in a run and whats going on
almost guarenteed that your output isnt temperature calibrated anyhow so your litteral alcometer readings wont be right in the first place
you make you numerically accurate readings after everythings said and done and you re makinging your cuts at the proper temperature
My parrot is 3/4", fed to the bottom, and I have two alcometers. One is the 5/8", the other is 1/2" (bulb dia.) The smaller one is definately more stable during a run.
Hawke wrote:My parrot is 3/4", fed to the bottom, and I have two alcometers. One is the 5/8", the other is 1/2" (bulb dia.) The smaller one is definately more stable during a run.
Exactly.
Larger clearance between hydrometer and cylinder wall = more stability
Cheers.
2"x38" Bok mini and
I feed mine up about 2 inches from the bottom but still below the hydrometer. The 1 inch tubing will work a little better due to more clearance . Here is how mine is set up.
Experience is something you don't get until just after you need it.
Gee That's nice and shiny, do you polish it after every run
LoL. .. No I just made a new one last week and it was still unused at the time of the pic. It doesn't look that way now.
*drool*squeezins wrote:LoL. .. No I just made a new one last week and it was still unused at the time of the pic. It doesn't look that way now.
PORN ! ! !
*drool*
