Hi from Christchurch, NZ
Anvil
Post by Anvil » Tue Jan 05, 2021 6:34 pm
Hi Everyone,
After many months of reading this forum, digesting and experimenting, it is time to say 'hello'!
After trying smaller gas fired boilers, I'm now running a 50l keg boiler with 2x 2kw electric elements, a simple pot-still head with a liebig condenser for stripping runs and a 65mm diameter bokakob reflux head for making neutral. Then making gin in a 5l copper alembic still.
A special thanks to the makers that have posted construction, plans and soldering advice, and to those gin-makers that have forged the path for others to follow (special thanks to Odin and NZChris to name a couple - there are many more).
After making a few passable gins and many not-so-good, my New Years' resolutions are to:
1. stop drinking the good ones before they are the mandatory five weeks in the bottle.
2. be more analysis driven, rather than experimental - I don't know enough about what I'm doing wrong, so need to reduce the variables!
Thanks again to all the experienced distillers that are sharing their knowledge.
Cheers, M
SaltyStaves
Re: Hi from Christchurch, NZ
Post by SaltyStaves » Tue Jan 05, 2021 6:44 pm
Welcome to the forums.
Sounds like you've got yourself setup for just about all you could ever want. Took me a while before I had more than my main pot still and still haven't sorted out a reflux solution.
Master Distiller
Post by NZChris » Tue Jan 05, 2021 7:12 pm
Welcome to the forum.
SassyFrass
Location: Sittin' on the side of the Mountain sippin' and smilin'
Post by SassyFrass » Tue Jan 05, 2021 8:20 pm
Hello and welcome. Sounds like you are well on your path. Still a lot can be learned. I learn something new just about every day.
Have fun a d stay safe.
SF
Real good info for New Folks:
