New member here
- Whiskey_Mike
New member here
Hey y’all I’m from California and use an 8 gallon milk can with a 2 inch copper column with a shotgun condenser. I use a 1500 watt electric heater element to run the still. I’ve got a few runs of sugar shine under my belt with good results. Looking to get into AG distilling especially wheated mashes. Been doing a ton of reading and already picked up a lot of good info thus far. Cheers looking forward to learning more
Re: New member here
Welcome, Mike
Buck Owens
Buck Owens
- Twisted Brick
Re: New member here
Welcome, Mike. Fellow CA native here.
Twisted
Twisted
Re: New member here
Hey dude Yur rig sounds cool , I’m also in Cali , I’ve got a few rigs a 5 gallon reflux from stillspirits.com , a 15.5 gallon homemade potstil/ reflux I made
From a keg and a 40 gallon homemade unit I made converted unit I made from an emergency stainless eyewash tank that was intended for eyewash in a chemical facility in case someone got their eyes splashed with harmful stuff …. The tank is amaizing the column I use on it is a sleeve for a UV water filter it’s also stainless & I pack it with layers of copper scrubbers & pre 1981 pennies. This is my main unit I ferment in 55 gallon food grade drums & I mostly do all grain whiskey mash where I ferment I the grain , which does not require me to separate the solid grist From my wash . When the grain floats on top of the wash ….. I transferred wah to another or several other vessels ….. prior to distillation I like to refrigerate my wash to allow the solids to sink and “ rack” ;””btw I hate this term”” …. The fluid free Fromm suspended yeast & grist solids off into the still & cook it . My distillation process is my own secret method I won’t disclose to just anyone but it obviously changes depending on if I’m stripping , using a lot still , reflux , if I have a tall column , if I’m using plates etc. It’s so variable from that point on . & it’s continuously variable even further as ther is so much margin for creativity which is why this subject is indeed a formidable artform. Now …. Let’s talk shop
Re: New member here
Welcome Mike., what do you mean by column.Whiskey_Mike wrote: ↑Sun Jun 13, 2021 4:52 pm can with a 2 inch copper column with a shotgun condenser.
A packed column? A plated column? Or maybe just a pot still with a long riser.
It gets kind of confusing if we don't all stay with the same lingo.
- Whiskey_Mike
Re: New member here
It’s just a pot still that I’ll sometimes pack with copper to get a little reflux going [IMG]https://uploads.tapatalk-cdn.com/202106 ... 5d2626.jpg[/IMG]
Re: New member here
Welcome! And I thought I was behind enemy lines... you got me beat! Nice rig.
Re: New member here
Ok thanks.....more correct to just call it a pot then.......saves confusion for all.Whiskey_Mike wrote: ↑Mon Jun 14, 2021 6:50 am It’s just a pot still that I’ll sometimes pack with copper to get a little reflux going.
Any reflux from packing that won't be noticeable.....or be an extremely tiny amount
Re: New member here
Welcome to the forum Mike
Slainte
Slainte
