Corn Syrup & Malted Barley/Wheat
Hi there !
I'm living on the other side of the world (where, btw, shining is tolerated),
and here they have a lot of Corn syrup (maltose).
I was wondering... Would there be any reason for this to not work as a complement for grain worts?
Or even as a sugar mash by itself? I'm aiming on shining Gin almost exclusively.
Would that be a good base for the task?
Here, they also have Yeotkileum, which is used for tea in Korean customs. And it's cheap.
This is malted barley at 70% and malted wheat at 30%.
I'm a beer homebrewer originally, so I've been experimenting to use it several times to make beer,
but the taste is not that great... So I'm sticking with my homebrewing expensive malt.
I was wondering if anyway, once distilled with a pot-still if there are chances for it to taste better
than the fermented wort?
Cheers !
Cheers !
All Grain Beer Brewer
Re: Corn Syrup & Malted Barley/Wheat
Hi Elut,
I don't think you need a grain based wort to make gin. Something more neutral would be cheaper and more appropriate.
Never heard of Yeotkileum, sounds interesting ... if it's cheap!! Cheers, bd.
I do all my own stunts
gin is a macerated spirit, so you want a good neutral as you base. that means you want a good tall reflux column to pull pure +95%
to make good gin you have to make a good vodka first
if you have a good reflux column, just about anything that is fermentable can be used since all the flavors will be stripped from them anyways...
I make gin by fermenting 25lt of neutral sugar wash, and hang a bag of botanicals in the neck of my boiler, ( see my thread for "Gin Clip"
The botanicals in the bag are
4 teaspoons full of dried juniper berries
5 almonds
good strip of orange peel
good strip of lemon peel
1/2 teaspoon of orris root
1/2 teaspoon of angelica root
1/4 of a star anise
1/2 teaspoon of ground ginger
1/2 teaspoon of cinnamon or about an inch of cinnamon stick
1/2 teaspoon of grains of paradise ( coriander seeds)
Put the botanicals into a spice/coffee grinder and grind to a coarse grind, put this mix into a small muslin bag and hang in the neck of your boiler, attach your column and distill. The quantity af botanicals are for a 25lt wash, adjust accordingly.
This makes a gin close to Bombay Saphire gin ( my wife thinks its better)
5 almonds
1/4 of a star anise
Sounds like a nice recipe olddog.
Where do you source Orris root & angelica root? I've never heard of them
Thanks a lot for the feedbacks guys and for the great recipe as well.
I'm gonna make the Gin with a pot still, not a reflux. So I'm looking for a pretty neutral wash.
From my beer brewing experience, once fermented, that corn syrup doesn't taste anything, so I guess that I'm gonna go this way.
Thanks again !
Thanks again !
Aces high: I got orris root & angelica root online from an Ebay store in Queensland
Elut: I aways use a potstill with thumper.
I just remembered that I have a full bucket of the stuff I used to use for candy. Much better for mind candy. Cheers, bd.From my beer brewing experience, once fermented, that corn syrup doesn't taste anything, so I guess that I'm gonna go this way.
edit - do you know if sugar and glucose can be swapped one for one?
Elut, the yeotkireum WILL work, I've used it myself for a few all malt mashes. It mashes very easily. I didn't make much of it though because I found the resulting distillate to be very aggressive for my taste. I also thought it was a bit expensive at 2000 won per 500g. I have since attributed the aggressive taste of this malt whiskey to my lack in cutting skills. I have been using it in my last 4 ujssm washes at a rate of about 15 % of the grist. I leave it in for two generations, then replace it. It's easy to replace because it floats to the top and acts like a cap on the wash. I really like what it is adding to my wash. I believe I have since gotten much better and far less greedy with my cuts and will probably revisit the all malt using the korean malted grain. By the way they also use it during the making of soy bean paste (which I love). I assume you are in korea...what part, if I may ask? I'm up near uijonbu myself.
The Pure Drop
- thepatchworkdoll
Hey Olddog
Like the sound of your Gin recipe. Can you please advise that when your Gin is mixed with tonic etc. it does not louche.
Regards
Patch
Regards
Patch
Hey man. Uijeongbu... On base?the pure drop wrote:Elut, the yeotkireum WILL work, I've used it myself for a few all malt mashes. It mashes very easily. I didn't make much of it though because I found the resulting distillate to be very aggressive for my taste. I also thought it was a bit expensive at 2000 won per 500g. I have since attributed the aggressive taste of this malt whiskey to my lack in cutting skills. I have been using it in my last 4 ujssm washes at a rate of about 15 % of the grist. I leave it in for two generations, then replace it. It's easy to replace because it floats to the top and acts like a cap on the wash. I really like what it is adding to my wash. I believe I have since gotten much better and far less greedy with my cuts and will probably revisit the all malt using the korean malted grain. By the way they also use it during the making of soy bean paste (which I love). I assume you are in korea...what part, if I may ask? I'm up near uijonbu myself.
We moved to Europe a few months ago, but still fly to Hangook from time to time.
We used to live in Kyeonggi too, in Suwon. If you're up for a pint or ten next time...
