Ok, so i've not been having very good luck with my mashes. For a 12gal batch of mash I had 18lbs of course ground barley, 7lbs of liquid malt, teaspoon of amylase.
I boiled 5 gallons of water along with the malt for 10 min after boiling started. i added this water and malt to my 12 gal tub along with the 18lbs of dry barley, I let that combo set till it cooled off, which took 12hrs till temp was low enough to add yeast. I also added the liquid amylase before i let the mash sit for 12 hrs till yeats pitching.
I did get fermentation, but I dont think i'm getting enough conversion of the starches.
What am i doing wrong.
Trouble Shooting My Mashes
If it dont burn it aint good!
Proudly tearing up the blacktop since 1996!
Is your barley malted? What was the temp of the mash after you add the water/extract mixture to the grain? It should be about 65C (definitely not above 70C or below 60C) if you are using malted barley and relying on that for conversion.
I've never used amylase enzyme additions but from what I have read it is usually only alpha-amylase, and you need alpha and beta-amylase for successful conversion of starches to fermentable sugars. Check if your amylase is a combination or just one.
Cheers,
J
Cheers,
J
You should read through http://www.howtobrew.com" onclick="window.open(this.href);return false;" rel="nofollow esp the section on all grain brewing. And the parent site under recipes>grain has some pretty straight forward instructions in many of the recipes.
Cheers,
J
Cheers,
J
