All grain brewing, filtering and rinsing purpose.
Postby Aidas » Fri Oct 26, 2007 10:27 pm
stoker wrote::o , for you that must be more then 2000 km!
it would be a very expensive mash tun :?
Oh, it's a two day drive with one overnight in Prague (if I remember correctly, from Klaipeda to Brussels, it is 1600 km. plus/minus...) Besides, It would be an excuse for a road trip, and to try some of Bujapat's products :wink:
I go to brussels pretty often (for work), but I wouldn't mind going down for whiskey matters :lol:
AIdas
Nisi te iuvat cibus, plus bibe vini!
Aidas
Postby goose eye » Sat Oct 27, 2007 3:51 am
heckofva job
you done good
goose eye
Master Distiller
Postby Bujapat » Sat Oct 27, 2007 5:23 am
So, my brewin' setup isn't finished yet...
I'll tell you when the first test will be achieved.
But, in any case, it isn't for sale !!!
Aidas, when you come to Belgium, let me know... It would be nice to meet you ! ... and test some of my products ! Image
I'm french speaking!
Bujapat
Re: All grain brewing, filtering and rincing purpose.
Postby big_daddy_d » Tue Sep 16, 2008 3:27 am
http://www.portablemilkers.com/catalog/ ... 587812.htm
I found this this mourning looks like it would work awsome for straining mashes in to distiller or another bucket
big_daddy_d
Postby big_daddy_d » Tue Sep 16, 2008 3:30 am
The milk jugs they have listed have drain tubes in the corner would be good if you could get a welding shop to weld you a adapter to it so you could put a vavle on it to drain it.
big_daddy_d
Postby GreenEarth » Mon Nov 17, 2008 10:25 pm
Awesome Job on that Mash Tun!!! and I loved your posts on the Rice Likker too! thanks
For A Better Earth, Or A Better Buzz!
GreenEarth
Re:
Postby blanikdog » Tue Nov 18, 2008 1:46 am
CoopsOz wrote:I for one couldn't achieve that level of work!
you're not alone there, coops. Beautiful work!!
blanik
Cumudgeon and loving it.
blanikdog
Re: All grain brewing, filtering and rinsing purpose.
Postby irishman » Fri Feb 03, 2012 8:01 am
First off, that's a sweet Mash Tun!
Secondly, why the stirrer? You have to be careful with them, or you'll end up creating cavities in your mash and channeling when you're running off your wort. Creates an effect that lowers your extraction of sugars from the grain.
irishman
Postby AndyC » Wed May 16, 2012 4:42 am
Oui!
Nicely nicely Vincent Pricely
Definitely looks better then professional, looks artisan, if you do any more projects please post pics.
AndyC
Postby firebirdude » Wed Jun 06, 2012 5:21 pm
So it's been a few years.... updates? How's it working out for you?
firebirdude
Postby bbonser » Sun Aug 12, 2012 4:15 am
I was briefly reading through this thread and not sure if it has been mentioned here or not but another option to soldering the input and output tubes would be to use Weldless fittings like the ones at http://weldlessfittings.com/kettlefittings.html or just google Weldless fittings or weldless keggle fittings. Brewers have had good luck with these.
bbonser
Postby tom sawyer » Wed Aug 22, 2012 6:17 am
Wow that is one of the fanciest mashtuns I've ever come across!
For those of you that are on more of a budget, have you heard of a cooler mashtun and batch sparging? This is what I do for my brewing. I have cooler MLTs (mash/lauter-tuns) of 3gal, 5gal, and 15gal. The big one holds 30lb of grain with a mash ratio of 1.5qt/lb.
Check out Denny's cheap and easy cooler mashtun. The cooler holds the heat nicely, the braid serves to set up the grain bed that does most of the filtering, and batch sparging means you don't need aa fancy sprinkler head. You mash, drain the sweet wort, add sparge water and stir, then drain that off.
http://hbd.org/cascade/dennybrew/
tom sawyer
Postby Mrek_09 » Mon Feb 17, 2014 1:50 am
Nice post. I enjoyed reading this forum. i am thankful to all members for their helpful replies.
Mrek_09
Postby Prairiepiss » Mon Feb 17, 2014 11:05 am
Holy old thread resurrection Batman.
Someone was looking for this thread the other day. Now who was it?
Prairiepiss
Master Distiller
Postby bearriver » Tue Mar 11, 2014 11:13 am
Sticky worthy, I saw this awhile back while digging around.
Been in my head ever since....
bearriver
Postby Antler24 » Tue Apr 01, 2014 8:28 am
I'd do some more research on that "shower" if I were you. That garden hose is more than likely to carry a rubber taste into the water, but beside that the shower is going to cause bubbles in your mash, which beer brewers refer to as Hot Side Aeration. I'm not really sure the affects but all brewers (beer) try to avoid it.
Also I think you'll have problems burning grains with your element in the mash vat. Most beer brewers use a second keg full of water with an element. The wort water comes from the mash vat, through a coil in the water keg and back to the mash vat. It's called an eHerms system, works like a worm and flakestand but for heating mashwater instead of condensing vapours.
Swedish Pride wrote:
Antler24
Postby bearriver » Mon Apr 14, 2014 6:42 am
Besides being a dead thread...
His heating element isn't in the lauter tun. It's in a separate keg for boiling his strike water. Plus I doubt he used the hose except when he first tested it.
Lastly I doubt the manifold matters. The sparge liquid is often used for the next ferment instead. Efficiency hasn't been a concern I see tossed around here, like it is in the beer forums.
bearriver
Postby JayG » Wed Jan 28, 2015 10:29 am
If efficiency isn’t it sure should be. Why waste sugars/flavors/alcohol by not removing all the sugars from the grains? Reason you’re taking the time to properly convert them. As a brewer it very important to me. I see no diff as a distiller. Max efficiency and control at all points for best end results is my goal.
Awesome setup by the way. Looks great. :clap:
I just add a little heat if needed to hold temp and recirculate the running’s. Then sparge off the last of the sugars in a second running to get the volume I targeted. No need to insulate that way. I can hold a 151 temp forever even in the winter as I’m doing now. I made a cross sparge arm. After several batches I removed the arms. Not needed at all as far as I’m concerned. I do a very fine crush as well. As long as you have a false bottom and pump to recalculate you should be good to go. I test for conversion at many points in the mash. I can tell by the bubble size and colors now. Sticky sweat stuff.
I just put this link on another post. Shows my grind, kegs, how I’m mashing, and my false bottom. Added advantage to mashing like this is the grain bed is your filter. My wort/brew runs clear before I pull it off. No need for any filtering after it’s fermented. I also converted a chest freezer to ferment in. Holds whatever temp I set it at for best results of the yeast I’m using. More control the more consistent your final products will be.
https://www.youtube.com/watch?v=iNHDRzcA52g
JayG
Postby poitindrinker » Thu Mar 26, 2015 1:35 pm
That's an awesome mash tun.
give a man beer and he will waste an afternoon teach a man to brew and he will waste a life time, teach a man to distill....enough said.
poitindrinker
Postby Dunder Dan » Mon Sep 14, 2015 6:39 am
Here's mine in progress!
Dunder Dan
Re:
Postby BaxtersDad » Mon Sep 14, 2015 12:24 pm
You said it! I also thought the steel hose was not necessarily the best for wort collection though. I have been an all grain homebrewer since the mid 1980s and I am in the Jack Schmiddling EasyMasher (tm) camp which I found to be a bit more efficient that a false bottom, and I also don't understand why a heating element is necessary on an insulated mash tun, but those are just details. The build blows me away!
bronzdragon wrote:These craftsmen just do this to make the rest of us drool! hehe
Just kidding. I've been a homebrewer for about 15 years now and that's one of the best mash tuns I've seen made at home for home use.
I may have went with a false bottom instead of the cut pipe as far as catching the runoff ... but it probably doesn't matter much. It may depend on what you intend on mashing mostly.
It looks like a top notch set-up.
~r~
BaxtersDad
Postby buckfity6 » Sun Apr 17, 2016 9:17 pm
Dam fine work!!!!
Wow guys that's a work of art.
buckfity6
Postby badflash » Wed Apr 04, 2018 2:32 pm
I've been doing all grain brewing for a long time. It is really simple to go to Home Depot and buy a 10 gallon Igloo water cooler, pop out the water valve and back fit with a false bottom and a ball valve. Any home brew shop has this. Sparging is over rated IMHU. I add the crushed grain, then hot water to get the mash to about 155, stir it up and let it set for an hour to convert. Let it drain, off and squeeze out the last of it with a dinner plate. I run boiling water through the 2nd time to get the 2nd run, and it is ready to ferment when it is cool enough.
Great work BTW- but I don't have the skills or the patients for that.
badflash
Previous
Return to Mashing and Fermenting
Who is online
Users browsing this forum: No registered users and 2 guests
