Ah...I just blew a huge post here...
I got six oyster shells from a local eatery...they throw them away! Washed and scrubbed them in water with a SS Scrubbie. They still stank, so I soaked then in water with added citric acid. Hoped it would cause some quick action and clean the outside. Did, but, still smells a little fishy. Used it this way...anyway.
I added an 98 gram piece of shell to a 2 gallon rice test ferment that was almost finished, and it went from 3.1 - 3.7 in twelve hours and has stayed at 3.9 for two days.
I have done two other tests...I started with a quart of water at 3.0 and added a 87gram oyster shell. Measured ph at 12 hour intervals.
3.0 Ph start, 4.2, 4.8, 5.2, 6.1, 6.7, 7.4, 7.4,...
I have two inexpensive Ph meters and both are calibrated in bought solutions.
Then I went the other extreme, starting at Ph 9.4, 8.8, 8.6, 8.2, 7.7...wait a minute...it's going down?
I started reading about Ph buffering and found there is a relationship between Ph, Gh and Kh...that can be controlled (buffered) by finding a balance between the three.
Per Hydrogen (pH)
The pH of the water is a measure of the balance between the Hydrogen (H+) and Hydroxide (OH) ions in the water. I think most of us know that low pH is acidic and high pH is alkaline or basic. Hence a pH of 5 is slightly acidic water, a pH of 7 is neutral and a pH of 8 is alkaline water.
General Hardness (GH)
This is essentially a measurement of Magnesium and Calcium ions in the water. Again it is measured in the German degrees of hardness scale or parts per million. This is what is generally meant by soft and hard water which are terms people should be familiar with.
Carbonate Hardness (KH)
This is an area where many people get confused. One of the reasons the term alkaline is avoided a bit and the term Basic is used for the pH scale is because this reading is measuring the alkalinity of the water. It is not the same as alkaline.
The alkalinity is a measurement of the waters buffering ability, or its ability to absorb and neutralise acid. Clearly the more alkalinity or the higher the Carbonate Hardness of the water the less likely you will incur pH swings in the water. It is therefore important to get this figure reasonably high to stabilise the water.
Did you guys know all of this? I knew about Ph and Gh but not the relationship.
There is another group of hobbyists that worry about the same things we do in a ferment. Koi pond owners! Just like us they raise critters in a confined environment that shit in the tank and acidify the liquid.
OH and THEY USE OYSTER SHELL AS A BUFFER!
They say that oyster shell will reach an equilibrium between Ph, Gh and Kh at Ph 7.4. Once or if the liquid reached 7.4...the shell will only be active if there is an acid condition that upsets the equilibrium.
Now that's higher than we want for our critters, but it takes a long time to reach that equilibrium. So, during the normal time for a ferment the oyster shell will be trying to balance the Ph as it adds minerals (improving the Gh and Kh). Most of those minerals will also be beneficial to the yeast.
Also, harder water, Gh, the addition of other minerals can slow the Ph change caused by the oyster shells. I don't know what other minerals or that we want to slow it.
OYSTER SHELL
Oyster shell chemically consist of 95% calcium carbonate,3.5% silicate and a trace of other elements like aspartic acid,glycine,calcium phosphate,zinc,manganese,aluminum,... that were in the water it grew in.
So, what else did I learn about Koi ponds and Ph? They also line there Koi ponds with Limestone for the same reason. So I imagine that if you are squeamish about oyster shells, you could use a small block of lime stone or even a concrete block is suggested.
This makes me think of Jack Daniels and their limestone cave spring! Or the old timers using creek water. Most city water is too soft (low minerals). Then we torture or water before the ferment starts! Boiling removes the oxygen, mashing makes it acidic,...it's a wonder the yeast survives at all.
Calcite (limestone)
Limestone is a sedimentary rock composed largely of the minerals calcite and aragonite, which are different crystal forms of calcium carbonate (CaCO3). Most limestone is composed of skeletal fragments of marine organisms such as coral, forams and molluscs.
Shells and minerals...Ever heard of cement fermentation tanks...hmmmm.....
http://concretebeertanks.com/concrete-t ... tures.html" onclick="window.open(this.href);return false;" rel="nofollow
