Corn Vodka
Corn Vodka
So I have a sack of some amazing flaked corn, I've made a couple batches of 40% distillers malt, 55% corn and 5% rye malt whiskey. The results have been good. I was discussing doing a 100% corn or 80% corn/20% Sugar vodka wask to run on a reflux still for a 90-95% spirit. My question is I have a bottle of enzymes, and potential alcohol strength (gravity)
First, how much enzyme should I use per lb or Kg of corn?
Second, I'm considering using just an EC1118 yeast, pinch of nutrient and some energizer (yeast hulls). We were discussing and since this is not going to be a Whisky just a neutral spirit. How strong can we push the yeast. With Whisky I've been going a little under 8% on my washes. Will going up to 11%-12% be a big problem with flavors and undesirables? Usually with my rum washes I hit 10.5% to 11% without an issue.
long live Oldsmobile Aleros
Re: Corn Vodka
Depends on what kind of enzymes you have. Powder , liquid , amylase ?
Yahoo Mountain Dew ! It'll Tickle You're Innards !
Re: Corn Vodka
So a Google search for your brand of enzymes. They should have sent you instructions with them.
I'd keep the ABV around 10%. And use bakers yeast, a lot cheaper and likes corn ferments.
I made a vodka from UJSSM by triple distilling. Very nice with a slight hint of corn.
Re: Corn Vodka
I prefer wheat-based vodkas but I've made a few batches from corn. SEB enzymes are used at 0.36 ml/lb ... I usually just toss a tablespoon per 12 lbs of grain. That's worked every time.
________________
Re: Corn Vodka
Booner's in the T&T makes great vodka.
- scuba stiller
Re: Corn Vodka
+1bearriver wrote:Booner's in the T&T makes great vodka.
Cranky's Spoon Fed Information http://homedistiller.org/forum/viewtopi ... 15&t=52975
Re: Corn Vodka
The enzymes I've been using require both .36ml of alpha and gluco per pound of grain.aircarbonarc wrote:First, how much enzyme should I use per lb or Kg of corn?
Re: Corn Vodka
So I've decided to go with 14gallon wash, about 12lbs of corn, 5lbs of 2 row I have left over and about 22lbs of inverted sugar. It'll have hopefully have a gravity of 1.108 and a final of 1.025. ABV of 10.88%. Wondering if I should maybe swap out the 2 row for more corn and use my liquid enzymes or wheat malt for flavor sake. ... I guess the worst thing will be activated charcoal filtering if it tastes funny.
- Master Distiller
Re: Corn Vodka
Why use enzymes and go to the effort and trouble to mash in then dump sugar in to the point that its not even gonna finish dry and possibly cause foaming ,puking,and scortching? How about trying the booners rescipe in t&t by woodshed. Try for a og of 1.060-1.070 and ditch the carbon filtering. Quality over quantity....
Jb
Jb
Deo Vendice
Deo Vendice
Re: Corn Vodka
Agreed. Don't waste enzymes if you're just going to throw sugar in there.
The sugar alone will make 11% ABV. Adding the sugar from the grains is gonna up that even more.
Re: Corn Vodka
http://www.brewersfriend.com/allgrain-ogfg/" onclick="window.open(this.href);return false;" rel="nofollow
I was using this handy calculator, wanted to make a full grain vodka but figured sugar would stiffen up the ABV and cut down on the use of full grains. So this calculator is... Maybe processed meat named after a region of Italy? Bologna"
Re: Corn Vodka
>wanted to make a full grain vodka but figured sugar would ... cut down on the use of full grains.
Do you see the contradiction there ?
________________
Re: Corn Vodka
+++++++++++1greggn wrote:>wanted to make a full grain vodka but figured sugar would ... cut down on the use of full grains.
There is a reason all grain is preferred over grain+sugar when making vodka. Both can make a fine drop, but try a strictly all grain and compare it to a sugar head. Keep note of which has more bite. Oh, and no cheating with charcoal filtering. We do it ourselves so we can do it right and not have to rely on tricks. If you need to clean up off flavors, rerun it.
Re: Corn Vodka
I suggest to use your corn and enzymes to nake an AG corn vodka. Use your sugar to make a sugar wash. Save your barley for a whiskey batch. Run them separately and if you're not happy with the individual products you can blend ... or re-run.
________________
Re: Corn Vodka
Corn make a great vodka. Very sweet on the back end. Don't use sugar. It's just a waste for vodka. Make a sugar head on the spent grains for a corn whiskey.
Try a 50 /50 corn/wheat for a phenomenal vodka. Perfect blend of mouthfeel and sweetness (subtle) personal preference anyways.
Yak
Yak
Re: Corn Vodka
I will try that!! Good idea actually!! I'll let you know how it turns out. I'm thinking of using EC1118 with a bit of DAP and some yeast hulls to satisfy the cannibalismyakattack wrote:Corn make a great vodka. Very sweet on the back end. Don't use sugar. It's just a waste for vodka. Make a sugar head on the spent grains for a corn whiskey.
Yak
- Kegg_jam
Re: Corn Vodka
I used EC1118 with a corn mash once. Didn't turn out that well. Had some funky sulfur smells. Went away eventually but I don't get that with DADY or bakers.
Re: Corn Vodka
I've had good results with using an American ale yeast with whiskey washes. I bought a good sized bag from my local brew store and its been serving me well with the AG washes, good flavor. Maybe try a dry ale yeast next time. Used still spirits whiskey pure and it just gassed so much sulphur the basement smelled like farts.
