The SG of each bucket when I pitched the yeast was 1.071 and only 24 hours later the SG was around 1.064 in each bucket. I felt like it was all going well and things were bubbling and fizzing vigorously. I had to go out of town for a few days, but the temperatures would have been anywhere around 71-80F (22-27C) depending on time of day and yeast activity. When I got back home a few days later the SG was still only about 1.030-1.043 depending on which bucket I tested and bubbling on all airlocks was very very slow. So this is 6 days after pitching. I measured the pH of the buckets using some test strips and I'm showing a pH of 3-4 for all the buckets. As a comparison my tap water (through a water softener) shows a pH of 7.5-8 and my RO filtered water shows about 6.5 pH. So it looks like the test strips are accurate.
Why might it be stuck or very slow at best? I was thinking I could do my second suger addition anyways today and see if things pick up. I do have a bottle calcium carbonate on hand if you all think I should bump the pH back up a few points. I'm not sure how much to add... however I would think it takes a good amount of CaCO3 to get 22 gallons of ~3.5 pH wash back up to 4.5-5.5 pH.
Here was my planned recipe and you can see it's basically a birdwatchers with a little more nutrient, more tolerant yeast, and I planned split up the sugar addition (all to help support more ABV%).
4 cups tomato paste
Juice 3 lemons
Approx. 48LB sugar
0.5 LB Fleischmann's Dry Yeast
3 tsp Epsom Salts (magnesium sulfate)
3 Ground Up Equate Women's Multivitamins
20.5 Gal Water
Boil 3 gallons water in 6gal kettle
Dissolve 32LB sugar in 3 gal Hot water (Sugar only dissolved, not inverted)
Mix Tomato Paste, and Lemon Juice into 16 Gal water.
Add dissolved sugar, ground up multivitamins and 2 tsp epsom salts.
Wort should be 21.5 Gallons at 23-30 C with SG of approx 1.068-1.075
Pitch 225grams Fleischmann's Dry Yeast (I used 8 packets of EC-1118 which was rehydrated instead)
Stir and check temperature daily. Check SG. When SG reaches 1.025 add more sugar & nutrient:
Boil 1.5 gallons Water in 3 gallon pot
Dissolve 16LB Sugar and 1 tsp Epsom salts in 1.5 gal boiled water and let cool to <33C
Add sugar solution to wash and stir well.
Stir and check temperature daily. Check SG for completion.
