Leftovers
Leftovers
Whenever I distill, I usually have leftovers. If it's a reflux run there's the heads and the tails. I double distill in the pot still so I have the foreshots, heads and tails.
Over the past year I've accumulated about a gallon of foreshots and 5 gallons of heads and tails. This is from grain, rice, sugar and grapes.
My reflux still gives me roughly 91-92% purity. Any suggestions on the best way to run and process all of the leftovers?
AkCoyote
AkCoyote
Hey Ak,
Linw is right, just run everything through the reflux column...thats what I do.
You'll be surprised how much you get back out of that 5 gallons. I'd suspect there is at least 1.5 gallons comparable to the sweetest middle cut you've gotten in the past.
Heads & tails
AK;
I usually mix my heads and tail in with my next run, that way you are carrying over on heads and tails from one run.
@AK, I don't rerun the foreshots but I collect the heads and tails to do a reflux run. Make sure you get up early because because its going to be a long day . The last time I did it I had 12 liters at 40%. My still ran for 15 hours collecting at 95-94% till I was finally done. On the bright side I had a lot of stock for over the holidays.
... I say God bless you, I don't say bless you ... I am not the Lord, I can't do that ...
Dane Cook
Dane Cook
yeah I also have the same experience as knuklehaed here. It's takes a long time to collect 94-95% though a reflux still.......
However if you would also be satisfied with a lower percentage (lets say 92-93) this greatly speeds up the process ..........
Also don't forget to add some sodiumbicarbonate. I have noticed that a lot of off-flavours are getten don't get through when you add it!
