I have a reflux still and want to take a swing at vodka as I’ve only done whiskey and it’s all aging.
Checked the good ol tried and true but only saw one and it was rice and want to do a grain recipe.
Checked you tube and saw potatoes may not be the best as they release too much water.
Thoughts? Recipes?
Looking for a grain vodka recipe
Reason: removed advertisement
Re: Looking for a grain vodka recipe
There are a few in tried and true. Wheat comes to mine. Turn off the phone app advertisement before posting in the forums
Hmmm I must have missed them. I looked twice but will try again
I’ve looked 4 times and don’t see any recipes for vodka in there. Do you know what they were called?acfixer69 wrote:There are a few in tried and true. Wheat comes to mine. Turn off the phone app advertisement before posting in the forums
I stand corrected in T n T their is no all grain vodka I never noticed that. Most do rice because its cheap and the rest do with faints from Grain runs through reflux. It's not the most economical way but I always do the first couple gens of UJSSM as a vody
but that is not what you asked.
You may want to try the recipe by "Bentstick" in the T&T section.. it's an all grain, and it is really nice white, and that is distilled at 80%.. if it was done at 95%, it would be very nice as a vodka, in my view, but then, everyone is different..
Here's the link.. viewtopic.php?f=14&t=62008
Also, you may want to look in the recipe development section..
Mars
Mars
– Albert Einstein
– Albert Einstein
I have no interest in vodka, but if I were to try it, I'd start with an AG wheat or Rice.
I recently made a wheat flour all grain using enzymes and double distilled it. I believe it would make a good vodka.
Checking now. Many thanksStillerBoy wrote:You may want to try the recipe by "Bentstick" in the T&T section.. it's an all grain, and it is really nice white, and that is distilled at 80%.. if it was done at 95%, it would be very nice as a vodka, in my view, but then, everyone is different..
Mars
- bluefish_dist
A simple single malt would work well as vodka or any corn whiskey recipe. Vodka is more about the distillation than the fermentation.
Here is my vodka recipe, it makes 110 gallons of wash. Adjust as needed. 82.5 lbs of 2 row rahr malt, 120 lbs raw sugar, .83 lbs red star bread yeast, .25 lbs distillivite GN, 1.5 lbs calcium carbonate, .75 lbs citric acid, 15 ml amylo 300, 15 ml fermcap at.
Start by bringing water up to 155 ish deg in the mash tun, add crushed grain. Add 2 tbsp citric acid and amylo 300. Let sit for 1 hr. Check for conversion with iodine.
Transfer wort to fermenter which has sugar in it already. The hot wort will dissolve the sugar quickly. Top off with cold water to get to 110 gallons, should be about 90 deg. Sg should be 1.07 ish. Add the rest of the ingredients, except for yeast. Once it’s mixed up check ph. It should be 5.2+/-.1. Dry pitch yeast. In 24 hrs check ph and adjust up if below 4.0. At 48 hrs sg should be about 1.0. Let it clear and run it.
I would do a strip run in a pot still, then add a small amount of baking soda to the low wines. Maybe 1 tbsp to 10 gallons. If it all reacts, add more. Then run in a column still to be between 190.5 and 191 proof. Carbon filter if you like, but it should not be needed.
Formerly
Dsp-CO-20051
Dsp-CO-20051
