Aquarium heater?
IDPotatohead
Aquarium heater?
Post by IDPotatohead » Tue Nov 03, 2020 5:56 pm
I bought one off of Amazon after reading about using them to heat washes on here. Then I started worrying about how it heats. Won’t it be super hot around the element possibly killing yeast, and much colder towards the outer edges causing slow ferments? Or am I over thinking it?
Durhommer
Re: Aquarium heater?
Post by Durhommer » Tue Nov 03, 2020 6:26 pm
Only use to heat up I was told then remove
bluedog
Post by bluedog » Tue Nov 03, 2020 6:28 pm
They get pretty hot, but they probably dont cycle on a ton, and submerged in an active ferment thats moving around a bit i really doubt it would ever be a problem.
stillanoob
Post by stillanoob » Tue Nov 03, 2020 7:14 pm
Hasn't bothered my yeast. I've had quick, no problem ferments with mine.
IDPotatohead
Post by IDPotatohead » Tue Nov 03, 2020 8:16 pm
Thanks guys. I won’t worry about it
Master Distiller
Post by NZChris » Tue Nov 03, 2020 11:06 pm
Heat rises, so run your hand over the fermenter to make sure the bottom is being heated.
Setsumi
Post by Setsumi » Wed Nov 04, 2020 9:57 am
there will be a lot of movement in your ferment to ensure displacement of heat throughout. as the ferment begins to finish turn it down and off.
press https://homedistiller.org/forum/viewtopic.php?t=79008
twins viewtopic.php?f=50&t=80886
Grappa-Gringo
Post by Grappa-Gringo » Wed Nov 04, 2020 10:04 am
I've used them in the past and still do-- the temperature gauge is flexible and you can adjust to what ever temp you need. To keep things moving I always give it a good stir.... usually done in 4-5 days... take them out of the fermenter prior to mixing, as they are fragile...
They say, "you are what you eat"... Then I'm fast, easy and cheap!
CopperFiend
Post by CopperFiend » Wed Nov 04, 2020 10:07 am
Used one and never had any issues.
Demy
Post by Demy » Wed Nov 04, 2020 10:43 am
I've used them for other purposes, I've never thought about fermentation. I usually use a heating band or ... nothing.
