Can I use 25% backset during mashing?
kyolic
Post by kyolic » Thu Mar 25, 2021 2:49 am
I made my first AG mash a couple of days ago. I mashed 10 kg flaked corn and 5 kg of malted barley in 45 liters of water and ended up with an OG of 1.065.
Now that I will have backset from this run, can I use 11.25 liters of backset + 33.75 liters of water (45 liters in total again), for the next mashing?
Will using some backset hurt the mashing process or anything?
Thanks in advance.
Master Distiller
Re: Can I use 25% backset during mashing?
Post by still_stirrin » Thu Mar 25, 2021 3:15 am
Backset will be sour (acidic) because the acids from a ferment (naturally occurring during mashing and fermentation) will concentrate in the boiler as you remove the alcohol along with some of the water. So, adding it to your next mash will lower the pH. But, to some degree a mild acidic environment is good for the yeast and the sugar reduction process. Now, if you start too sour it can retard the process.
Using 25% of your mash water as backset seems high to me, especially since you’re using flaked corn instead of ground corn (grains). The grains would actually help buffer the acids in the mash so it might work. But with flakes, you may have a pH crash in the mash tun. I’d start with 10% backset and check the pH. Then decide if you can add more, or you should add water to reduce the acid content. Remember, the conversion process will produce acid naturally, so you don’t want to overshoot your target.
Does this help?
kyolic
Post by kyolic » Thu Mar 25, 2021 3:25 am
Does this help?
Thanks for the reply SS.
So the only concern here is the pH right? I can use as much backset I want, provided that the final mash water pH is not lower than 5.5?
Tabucowboy
Post by Tabucowboy » Thu Mar 25, 2021 4:00 am
UJSSM tells you to use 25% backset. So it would should be fine.
But SS is right, I would watch if PH goes to low.
But Jesse's recipe does not mention that, so I am not sure how low it can go.
Cowboy
CM Reflux Still -- Copper mesh 16" ,column 31" tall, dia. 2",temp at boiler,top of column, power - PAC w5500w Element
Pot Still -- Copper mesh 16",column, 23" tall dia. 2", temp at boiler, power - PAC w5500w Element
kyolic
Post by kyolic » Thu Mar 25, 2021 4:24 am
Cowboy
We are talking about using the backset "during mashing" here. It is different from the regular usage.
8Ball
Post by 8Ball » Thu Mar 25, 2021 6:25 am
+1
I’ve used 10% cold backset after cooking my unmodified grains with HTL to help cool down & lower ph before combining with the malts.
Butch27
Post by Butch27 » Thu Mar 25, 2021 5:36 pm
Thanks in advance.
It's your mash, you can do what ever you want with it. Now the question should be "will it work?".
Post by Saltbush Bill » Thu Mar 25, 2021 6:46 pm
I agree with SS and 8ball.......10% would be a better starting point.
