How much backset is too much for sour mash?
Going to try my first sour mash tonight. I am going to make 6 gallons of my regular mash (70/30/10 rye, corn and malt). I have 6 gallons of wort left from my last run. Is a 50/50 mix of fresh mash and backset too much? Plan is for 12 gallons of finished mash. Thanks for any and all help.
Re: How much backset is too much for sour mash?
Your gonna need some good pH papers or meter to answer that question.
50% backset is way too much. Just guessing, I'd use around 10 or 15%
Mix it into the corn the day before cooking it.
- Stonecutter
I hope this info helps. Be sure to account for losses due to the backset that would normally be full of fermentable sugars. If that makes senseStonecutter wrote: ↑Thu Jun 03, 2021 7:07 pmJust came to the realization that 1.5 gallons of my mash was backset devoid of any substantial amount of alcohol this backset also watered down any OG reading I had taken before adding my mash liquid to the fermenter and backset, clearly a mental error on my part not to check my OG after adding backset. All this along with the natural losses incurred by flocculation and it’s no wonder I had a low yield.Stonecutter wrote: ↑Sat May 29, 2021 11:31 amThe thing that was disappointing is that I only collected about 1 liter of 60%. I usually get double that. I’m not sure what happened?? Maybe it’s due to a low volume or unconverted sugars or both. In the end I’m calling this experiment for making a sour mash with oats a success.
-Thomas Paine
-Thomas Paine
- Twisted Brick
+1
I have always made 12.5gal bourbon mashes. Early on I used a gallon of backset, but the mashes grew sluggish since backset from each successive batch grows in acidity. SOP now is a quart for 12.5 gallons. It doesn't take much to get my mash pH into the 'zone'.
I was just thinking about doing it for a different flavor, I am not in any need of adjusting my ph with it. My normal recipe works just great for me. I add about 7-8 lbs of sugar and another 6 gallons of water to the 6 gallons of grain after conversion. I was thinking of adding the sugar and then using the old wort instead of the second 6 gallons of water. Would that much throw off my already good ph level? Too much acid? Guess I'm thinking out load as I type....Thanks again for any and all advice.
+ 1....way to much
Understood, I'll back off the amount. Appreciate the help.
If you use backset to help unravel the starch in corn while it's cooking.
After the corn has cooled to mash temp, add a little calcium carbonate, such as oyster grit.
Then mix in the rye and malt.
Wrap it with insulation and stir it occasionally.
To be considered “sour mash” by regulation, it needs to be at least 25%. Of course, we can do whatever we wish.
I’ve gotten away with nearly 50% in a 1st generation UJSSM, but it’s too much. Required quite a bit of oyster shells to moderate the pH.
Now I do about 30%…
Now I do about 30%…
I use 25% going to move to 33% in the future..
