lowering ph
lowering ph
i been making boones all causal corn and its been being real good. i usually use back set to lower ph but don't have any at the moment. what else could i use to lower ph? and how long will back set last? does it need refrigerating? i have some that's about three weeks old but been in my hot shop with temps around 90 degrees.
- bluefish_dist
Re: lowering ph
Citric acid aka lemon juice works to lower ph. Citric acid is readily available. Should be at brew shops and maybe places that carry canning supplies.
Formerly
Dsp-CO-20051
Dsp-CO-20051
Re: lowering ph
thanks we keep lemon juice around ill try itbluefish_dist wrote: ↑Thu Jun 24, 2021 12:18 pm Citric acid aka lemon juice works to lower ph. Citric acid is readily available. Should be at brew shops and maybe places that carry canning supplies.
Re: lowering ph
I found citric acid crystals in the canning supplies aisle at my local grocery store. You can sprinkle it into a wash a teaspoon at a time. It’s not expensive and will store on the shelf for a long time. Oh, and while you’re there, grab a bag of pickling lime too, in case you have a crashing pH.
As to backset, I “can” it hot out of the boiler when I’ve finished a stripping run (the bottom drain is a “must have” on your boiler). I collect in pint mason jars and put the lid on hot. When it cools, it will vacuum seal. So it should last a long time in your “root cellar” with all your other canned foods, jams, and jellies.
Re: lowering ph
Here's my drunken thoughts
Since Booner's recipe only uses backset for the gluco half of mashing.
Without backset, the flavor may be a little different but conversion will be just as good.
The reason is, within a couple hours after fermentation starts.
The pH will naturally drop to what gluco needs.
Fermentation temp is a little low for the gluco to go fast.
But the gluco gets to nibble away and make more glucose available as the ferment progresses.
Re: lowering ph
I’m not suggesting that anybody do so but I’m curious if anyone has ever used something like a can of regular old cola to increase acidity? They all taste sweet from all of the sugar in them but I don’t know of any sodas that aren’t pretty darn acidic in nature. Just wondering if anyone has ever tossed a can of Coke into their mash?
But for real, if I don’t have backset I usually just add a cup of white vinegar as I’m heating up my strike water. Helps keep the deposits off of the element and kettle, too.
Re: lowering ph
Using vinegar will increase the amount of ethyl acetate in your finished wash, which will probably cause you to take a larger heads cut.Chucker wrote: ↑Thu Jun 24, 2021 5:37 pm I’m not suggesting that anybody do so but I’m curious if anyone has ever used something like a can of regular old cola to increase acidity? They all taste sweet from all of the sugar in them but I don’t know of any sodas that aren’t pretty darn acidic in nature. Just wondering if anyone has ever tossed a can of Coke into their mash?
Re: lowering ph
I haven’t really noticed an issue with it but that’s a good point and I thank you for noting it. I’ll try some citric and see what happens.
Still wonder about just adding a coke, though.
Re: lowering ph
Adding a coke will add unfermented sugar.
Which I suppose the wash will then ferment.
Re: lowering ph
Soda has preservatives (sodium benzoate). It might slow your yeast activity. Don’t think I’d consider adding it to a ferment personally.
- rubberduck71
Re: lowering ph
If you have access to it, Restaurant Store has cheap citric acid in bulk:
https://www.therestaurantstore.com/items/558607
https://www.therestaurantstore.com/items/558638
Re: lowering ph
Great point!still_stirrin wrote: ↑Fri Jun 25, 2021 6:04 am Soda has preservatives (sodium benzoate). It might slow your yeast activity. Don’t think I’d consider adding it to a ferment personally.
