Dropped some coal in the mash
Potiben
I am about to distill spirits by first fermenting a mash of sugar and water and then using a thermostat heater 30-45°C (86-113°F) to distill spirits.
I made a noob mistake and happened to drop some of the coal from the water lock into the mash in the bucket (this happened when I wanted to move the whole thing after mixing sugar, water and yeast).
Is there a problem in any way with some active coal in the mash while fermenting? It is not very much at all. Very little actually.
Re: Dropped some coal in the mash
It’s not a “mash”, it’s a sugar wash. A mash is made by processing grains by “mashing”. It involves temperature steps and holds to promote saccharification of the starches into sugars.
But, to answer your question … no, the activated carbon won’t affect the ferment at all. It is pH neutral so it won’t even help with the acidification that occurs naturally as a sugar wash ferments. It won’t change any of the flavors either. It will simply end up sinking to the bottom when the yeast flocculates.
Potiben
Thank you very much!
You might like to look through our Tried and True recipe section before you start your next wash.
Plain water , sugar and yeast is far from the ideal recipe for a sugar wash.
If you mean by this that you will then ferment it, then you might find 45C is to hot.......less than 40c would be better , some yeasts wont even like it that hot.
If you really do mean distill it then that's another whole ball game.
- Demy
No problem with charcoal ... I don't understand the temperature of 30-45 ° C ... you mean fermentation?
greggn
Saltbush Bill wrote: ↑Tue May 31, 2022 1:46 pm
He does ... he's running the Amazing Still.
________________
StillerBoy
He's using a plastic fermenter "advertise" as a still.. no wonder he's all confused.. and so are we also, cause he's making turbo wash..
Anything to make a dollar..
https://amazingstill.com/the-parts/
Potiben.. you need to stop whatever you are trying to do, and read more before continuing..
Mars
– Albert Einstein
– Albert Einstein
- Stonecutter
-Thomas Paine
-Thomas Paine
Potiben
Thank you people! I will read about this stuff!
bluc
Someone sells a plastic bucket with a heating elements as a safe boiler
and puts charcoal in an air lock?, Why, to sell more charcoal??
- EricTheRed
WTAF?!?!? Plastic still???StillerBoy wrote: ↑Tue May 31, 2022 4:14 pmHe's using a plastic fermenter "advertise" as a still.. no wonder he's all confused.. and so are we also, cause he's making turbo wash..
Mars
Life has gotten interesting!
- RC Al
Holy S#!7
and its
Wholey S#!7
and its
Wholey S#!7
- squigglefunk
