So i've started a bit to high (1.09 1.1 ish) and added at 3 different times, new yeast to restart fermentation. Also did a 1 time yeast nutriant booster. Now i am stock at 1.03 .... Would it be ok to distill anyhow ?
Thanks guys
Ferment stock... ok to distill ?
Re: Ferment stock... ok to distill ?
Better option would have been to add more water at the beginning to bring it down to 1.08 or so. But it sounds like to me that this is one of those times when there's just too much out of place with the environment to get it completed.
So yeah, you can run it, with the warning that It'll likely be quite foamy, and require a fair bit more cleaning afterward even if you avoid a puke.
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
Check your pH
got from 65% till 40%ish high 30% on that batch
What are you fermenting? If it's molasses it won't go all the way down.
Damn good question hawkwing and would explain a lot .
Guessing its a moot point now as OP has just ran it anyway . Regardless , a good point .
