Howdy y'all.
I recently ran about 20L of UJSSM. This was a second run, so it was a sour mash run.I added the spirits from the first run, and i did use a portion of the backset on the mash. Heres my trouble... I can't make heads nor tails.. much less hearts of it all. The first collection of heads was about (118ML). I'm switching out jars as soon as I can discern a significant difference in taste..trying to get the hang of cuts So, I didn't collect enough to measure with the hydrometer but the shake test made some quickly dispersing big-ole bubbles. Anyway, from there I collected about 2L of 60% -50% separated every 250ML after about 250ML of @ 40% I shut it down.
Too soon?
I mixed three of the cuts between 60 and 50% together and diluted to 45%. I put back the rest to use in my next run. well, as luck would have it, after about 2 weeks in the fridge, the "good stuff" had a whiteish-blue-green wormy-algae looking substance in it. not much, but enough to put me off. I mean hell, to be perfectly honest... it looked like a martian shot a load in my hooch! What is that stuff?!?!
I went and got the other portions I had set back as feints and gave them all a look.. some had "algae-worm" while others didn't. So, I'm thinking it was probably the jars and not anything from the still.
-stilltryin
Dilemma part deaux: The 40% stuff was crystal clear. And guess what... after it had set for 2 weeks... it tasted amazing! Did I miss this when I did my blending? or had this stuff actually changed, in flavor, in bouquet, over 2 weeks to something so good, from something that I passed off as "dregs" right off the still.
Did I cut it off too soon? I figured at only 40% I had to have been in the tails. I've read, on here, that most shut it down when the ABV drops below 40.
Tails and snails?
Re: Tails and snails?
Maybe you didn't get it clean enough on your cleaning runs? On making cuts, collect everything in equal jars, let them air out a couple days, then start in the midle and work your way towards the tails until you get to a taste you don't like, then work toward the heads doing the same. Then you have made cuts.
I did an initial cleaning run several months ago. Maybe another is in order since it has set up a while?wv_hillbilly wrote:Maybe you didn't get it clean enough on your cleaning runs?
I went straight to cutting. I see now, it's best to let it sit a while. Do you cap your jars? or let them "breathe"?wv_hillbilly wrote: On making cuts, collect everything in equal jars, let them air out a couple days, then start in the midle and work your way towards the tails until you get to a taste you don't like, then work toward the heads doing the same. Then you have made cuts.
Thanks for the comments.
Cover them with coffee filters. Lets them breathe and keeps the bugs out.stilltryin wrote: Do you cap your jars? or let them "breathe"?
Braz
Thanks Braz. I have some coffee filters perfect for that. (too large for my coffee maker)
I meant to also ask, at what ABV do you all consider the run complete?
I cover with a coffee filter and let them breathe for 48 hours. Do this for awhile, taste, feel, and smell them, eventually, you'll be able to tell the difference. I can pick tails off while distilling, and make my cut there over to bigger jars and take it down to around 20%. I still collect heads and hearts in smaller jars, though I can pick them off, then I'll air them out and reverify 2 days later. You'll get it eventually, and find a method that works for you.
