UJSSM, What the heck?
This is my second strip.
What is this crap? Showed up in my first strip.
Not sure if its foamy puke?
Re: UJSSM, What the heck?
Not sure - did you do a good cleaning run on the still to start with? I'd be inclined to run some more vinegar and another sacrificial run before running for keeps - doesn't look like puking per say.
Also, is the container in the picture plastic? If so that's an absolute nono.
I'm gunna first ask, did you clean the bucket first? Lol. Does the glob stuff look or smell or taste burnt?. does it have an oily consistentcy?.
"Homer J Simpson"
"Homer J Simpson"
Is that a growth? Hard to tell but It almost looks like Husks. I had husks floating in my ferment. Put the wash a paint strainer bag when charging the still. Last thought, maybe the still charge is too much and its puking. I guess it could be possible with a large charge and a fast strip to pull something like that through. Just spitballin here though.
I ran vinegar through it for a couple of hours.
Ran a sacrificial run.
Ran 2 stripping runs.
It seams oily.. But it will sink as well as float.
Not sure I want to taste it..
My distillate came off yellowish, so I dumped it back in the boiler and tried again.
Did this a couple of times with the same results.. That's why I think I may have overfilled it.
The bucket is what I poured it in to take a pic. It is HDPE.. From what I read it is ok to store ethanol in it?
I am in the process of scrubbing my column now, will try again.
I, and many of us here, use LDPE or HDPE fermentation containers, but most agree that anything much above 12%abv - and that includes stripped wash - is best kept in glass or stainless.Otis Campbell wrote:
LL
Having fun stillin' seriously..... This antique engine runs best on high octane.
Thanks folks,
I found it..
My column is filthy!
Seems the cleaning runs hardly helped at all.
I found it..
If you can see where it's dirty you should have already seen that and cleaned it as good a possible before ever starting your cleaning runs... The cleaning runs are only intended to help get the last bits out, not a whole sludge pile of caked on crud... Use a little elbow grease on it and then do cleaning runs over again from scratch...
And don't forget to wash behind your ears...
