First still build 3”ccvm
With the resources from this incredible site I constructed my second still ( first was a air still) its a 50 litre keg on 11” legs,1/2” drain in bottom,two electric heating elements a 1500 watt used mainly for heat up and stripping and a 4500 watt controlled by a 240 volt scr controller with amp meter. I ditched the 2” flange and put in a 7” tri clamp cap (to access for cleaning). Machined out center for a three inch triclamp column 40” high.1/2” Csst cold finger for reflux (I mostly do pot distillation) into two 3” tees leading into a 2” shotgun condenser that is at perfect height for my (built myself) parrot on a shelf ontop of the keg. I have two digital temperature controllers on both the vapour path and the condenser flow. She runs like a dream in both reflux and pot modes. Thanks for the help members cheers
- silverbean
- Location: Downunder If you don't like the weather, wait 10 minutes.
Re: First still build 3”ccvm
Nice. Looks simple, versatile and pretty. Good setup you have there.
The balloons are a nice touch.
Very beautiful.
Looks good, I like how you have your collection at counter level and don’t have to bend over. Also nice looking parrot.
- Twisted Brick
Great job on your build. Love the copper column!
Bottom shelf-stored beer always goes down nice.
Twisted Brick
Twisted Brick
Last edited by Twisted Brick on Wed Oct 07, 2020 12:21 pm, edited 1 time in total.
- Dewstiller
Looks Great!
Curious if your stand is welded/screwed to the keg or detachable?
Very cool! +1 on the fancy parrot.
Legs are bolted on with leveling bolts on bottomDewstiller wrote: ↑Wed Oct 07, 2020 7:04 am Looks Great!
- Dewstiller
Nice
Thanks for sharing.
Thanks for sharing.
You’re going to need a cap on the end of the tee that you are using for an elbow. If you can get your hands on a 3” elbow, you can then put a sightglass on that second tee and put it below the offtake tee
Modular 2" Pot Still
Balloons. Guess you didn’t notice the bottle opener on the wall hey. Lolsilverbean wrote: ↑Wed Oct 07, 2020 5:14 am Nice. Looks simple, versatile and pretty. Good setup you have there.
- Deplorable
I had to zoom way in after mentioned it. I love it.Newfie1 wrote: ↑Wed Oct 07, 2020 2:21 pmBalloons. Guess you didn’t notice the bottle opener on the wall hey. Lolsilverbean wrote: ↑Wed Oct 07, 2020 5:14 am Nice. Looks simple, versatile and pretty. Good setup you have there.
Hi kimbokimbodious wrote: ↑Wed Oct 07, 2020 1:14 pm You’re going to need a cap on the end of the tee that you are using for an elbow. If you can get your hands on a 3” elbow, you can then put a sightglass on that second tee and put it below the offtake tee
The pic that’s in original post was for reflux mode. I do cap ends of both tee’s. Second tee is used like an elbow like yours but offers a both easy clean port and a optimum spot for thermo well
Flipping great work. Congratulations and may great product flow.
Best, Drifter
Best, Drifter
Congratulations on your first build.......thats one hell of a step up from an air still.
Nice job! I’m curious about how your element is wired? Is that a kit? Or a specific plug. I just have loose wires on mine.
Anything worth doing, is worth doing well.
I found a couple plug end that were same diameter as the element outer end and made em fit. Barley and hops did a video on this using plumbing parts to make a water tight,shock proof,safe way to attach the elements.Simple Sam wrote: ↑Thu Oct 29, 2020 11:46 pm Nice job! I’m curious about how your element is wired? Is that a kit? Or a specific plug. I just have loose wires on mine.
Yes totally. Cuts are easier and better quality because of the larger amount in boiler (40 litres vs 4 litres) and only reducing from 3” column to 2” shotgun condenser makes for outstanding speed in both pot and refluxSaltbush Bill wrote: ↑Wed Oct 14, 2020 7:53 pm Congratulations on your first build.......thats one hell of a step up from an air still.
Uh....yeh, I did.
I always wondered why “brewers keep their beers on the bottom shelf” ... now I know!
