Pics are VERY welcome, we drool over pretty copper
Durhommer wrote:Oats will make it very smooth imo I did a batch remind me of bowl of sweet oatmeal
I hate oatmeal so I hope the corn hides the oatieness. I wanted a really smooth corn whiskey and I wanted to work with the grain I can get easily so corn and oats it is.
I plan to get some wheat and barley for the next couple batches. I plan to add at least one grain per batch just to learn what I like and what everything tastes like.
Currently I cant bear the thought of spending $50+ on a bag of malt so I am going to have to work on malting this summer as I can get seed quality grain easily.
Justinthunder wrote:Geeze where do you live? I just bought 10kg of malted wheat and 10kg of malted barley for 50$ and that’s Canadian lol
That's to many conversions for me. [emoji16]
My problem is that I would have to order off line and it seems that is not the cheapest way to buy.
I was referring to a 50 us pound bag.
I just checked SG and this one is a bit better 1.04 which is supposed to be about 5% potential alcohol.
It is sweet but I still haven't got iodine so I couldn't do a starch test.
Also I used one gallon of backset to adjust the pH for the second enzyme. Assuming my junkie Amazon meter is anywhere near accurate it should have been right at the optimal range.
One thing I've been wondering with regards to checking pH is I generally check it at whatever temperature the liquid happens to be because I haven't found anything to tell me I need to cool it down. Is there any temperature range that I should try to keep it in when I'm testing ph?
I am making a 2 gallon starter for the mash. I have been slowly adding mash a few cups at a time to the initial 500 ml of water and 2 tbsp of yeast and using a metal straw to blow bubbles in it to stir and oxygenate it. The yeasties seem quite happy and are not producing any alcohol smell so I assume they are reproducing aerobically.
If your blowing bubbles in it by mouth, then your introducing carbon dioxide, not oxygen....? EDIT...PH does change with temp....100c would give a neutral at 6.14.....
ismbardbrunel123 wrote:If your blowing bubbles in it by mouth, then your introducing carbon dioxide, not oxygen....? EDIT...PH does change with temp....100c would give a neutral at 6.14.....
Yeah I know my breath contains a lot of carbon dioxide but I also know my lungs aren't that good at removing all the oxygen and I mainly tried to use my cheeks to Puff air. Much less effective than an air stone but it's what I've got at the moment. I also used a whisk some but I got tired of rinsing the whisk a dozen times.
That is good to know that pH would change my reading. I will start cooling it first.
With that keg I was able to mash 20lb each of corn and oats in one pot so it seriously reduced my mashing time.
My OG was 1.04 so using an online efficiency calculator it looks like I got about 54.79% efficiency. This time I weighed my water so that I would know accurately how much I have.
I had ph problems on this batch. When I added backset the ph would not drop so I checked the ph of the backset and it was a a ph of 5. I have no clue why the ph was so high. The previous batch of backset was around ph 3.5.
I might have been able to get a little better conversion if I had been able to get the pH down to the optimal range for the enzyme.
1/2 gallon from 50lb of corn. I put all the heads and tails minus a generous foreshots cut in with the low wines from my 50/50 corn oats and added some strained mash. It is amazing how good that smells after a day.
It’s weird but to me no matter what kind of mash or wash I run, off the still smells like bananas to me, mind you I’ve only made sugar washes and grain mashes but fresh off the still is always bananas.
Justinthunder wrote:It’s weird but to me no matter what kind of mash or wash I run, off the still smells like bananas to me, mind you I’ve only made sugar washes and grain mashes but fresh off the still is always bananas.
That is strange. I love the smell of early heads fresh off the still. It is one of the few smells that I can smell from across the room. I can usually tell when the still is about to start running because I can smell it.
Yep, that smell of ripe banana and green apple means it's about to get busy.
I just got some oak ready for a booners all corn experiment. I am going to age 4 jars with 2 sticks each of oak at different char levels. All the oak was toasted at 375°f before cooling and then charring.
Zeotropic wrote: ↑Sat Feb 20, 2021 9:04 pm
IMG_20210220_230042001.jpg I just got some oak ready for a booners all corn experiment. I am going to age 4 jars with 2 sticks each of oak at different char levels. All the oak was toasted at 375°f before cooling and then charring.
Nice wood lol what a way to break it up and experiment a bit with the same batch! Let us know which you like better
Deplorable wrote: ↑Mon Feb 15, 2021 9:09 amYep, that smell of ripe banana and green apple means it's about to get busy.
And during the summer, the fruit flies show up too. They can smell the acetylaldehyde, amyl esters, and ethyl acetate long before you can. Just watch for them.
A half pint jar or a saucer of cider vinegar and a few drops of dish soap is an effective trap for fruit flies in the distillery.
I do that too in the summer I thought the wife was crazy doing it but it works!
I think it will take several batches but I will blend all the cuts before splitting it between the jars. I don't know how much corn it will take to make 2 gallons because I want to use 1/2 gallon jars.
That wood is the dirty sticks that I posted the other day. My step dad ran them through the table saw to clean them up.
I wonder if a bit of heads would make it work even better?
Deplorable wrote: ↑Sun Feb 21, 2021 8:31 am
Not in my experience. I've tried just leaving the lid off a jar of fores, and the vinegar attracts more fruit flies.
So deplorable do you mind showing me how you twisted your reflux condenser or did you already take pics
PM sent
