I have two heads to my still, a pot head and a Boka style reflux. My plan is to use the pot still for stripping runs and the reflux for neutral spirit runs. Today was my first time putting alcohol through the reflux and I'm surprised at how much slower this thing runs.
I ran 3 Gallons of 10% through (Watered down cheap vodka that was previously run through the pot still.)
I kept the output to 2 drops per second (I believe 2-3 is recommended based on the Boka guide) and was achieving 95% purity throughout the run.
Head temp was 174.7 throughout the whole run, didn't move more than .1 degrees throughout.
Output was 200ML per hour, which seems a little slow to me.
I am using the Alcoengine/Kegland Reflux head with the .6mm restrictor nozzle and valve at 100% open. It's roughly 2" x 20". After doing some research on the forum it appears that this is in the ballpark of what others were able to achieve with this small simple head.
My first reflux sac run
Re: My first reflux sac run
200 ml per hour seems very slow. Check that the orifice on the restricted valve is clear and that the breather hole is in the upright setting. Check that there is no PTFE plumbers tape obsctructing any of the connections.
Modular 2" Pot Still
The breather hole is definitely upright, I will double-check for any restrictions tonight. I saw other posts reporting 300ml/hr at 92% so I figured I was in the ballpark, maybe a little slow. Hoping to get things sorted before running a keeper spirit run.
The manual for the Kegland reflux still suggests output rates up to 1.2 litres per hour, assuming using the 1.0mm aperture restrictor
https://www.kegland.com.au/media/pdf/Al ... ctions.pdf
I wish it shipped with those instructions, I got a different set. I was using the smaller .6mm piece. There was also a little gunk accumulation behind the valve since it was the sac run.
All good, looking forward to reading about more successful runs!
Thanks for the guidance! I'm glad to know it should run faster in the future
