My first sac run.
- Tom Kat
My first sac run.
That was a good learning experience. I ran my still for 2.5 hours and got to test it out. I am glad I listened to SS and got a bigger pond pump.
I collected all of it so I could measure the alcohol content and smell the different cuts. I learned I probably need a bigger water tank (17 gallons).
So now it's time to start a new wash and play for keeps.
There's no place like home
- Deplorable
Re: My first sac run.
Before you make your keeper run, ditch all of the plastic jugs and funnel.
You could use a sheep tank instead of that plastic tub for your cooling water. You'll have more water, a larger surface area for heat to dissapate, and you can put your pump at one end and the return line at the other.
Before you know it, you'll have that corner of the barn walled in, a proper floor, and room to ferment!
- Tom Kat
I was thinking about a 55 gallon trash can I have for next time?
I have a bunch of jars but I didnt carry them out to the barn as I knew this was all going bye bye. And yes I need to arrange things, I have been multi tasking on the ranch. Its a busy time of year for me. You cant see it in the picture but I have a yard hydrant nearby.
- Deplorable
Dont dump all that saccrificial alcohol out. save it for future cleaning runs. Eventually, you'll find yourself building more still parts, and you'll have to clean them. No sense in making a new wash just for that.
I think 50 gallons is about the minimum amount of water you're going to need with that Liebig. Running at a good speed, you'll be putting a fair bit of water through it to keep the distillate cool. If your water jacket on the liebig was nearly as long as the vapor tube, you's use less water to cool the vapor due to the longer dwell time and contact with the water.
A good start.
And, it’s a great way to stay out of the wind...aye Tom? And, the temperature is falling too with this next cold front blowing through.
Although the tailpipe out of your Liebig is long, I do think that the condenser section would benefit with a longer cooling length. When you get to a hard stripping run, it will be easy to outrun that condenser. With the large (3/4” ID), you may notice some “puffing” of vapors out of the end. “Future improvement modification” though.
But, get at least one keeper behind you so you’ll have something to “motivate” you to move forward.
- Tom Kat
I can see the good of a longer condenser. That will be next I imagine.
- Tom Kat
Well then! Time to upgrade....still_stirrin wrote: ↑Sun Mar 21, 2021 3:41 pm A good start.
- Tom Kat
Perhaps 36" would be a better length? with copper wire soldered in a spiral fashion on inner pipe?
- Deplorable
I wouldn't go any shorter than 40 inches on the water jacket with a 5500W element. Better to overbuild it.
A 14g wire soldered to the outside of the vapor tube in the jacket will help. Put your input and output as close to the ends as you can. Is that 3/4 over 1/2 inch?
A kickstand would be a good idea to support the length of the liebig.
- Tom Kat
I have some 10 ga wire handy...yes its 3/4 over 1/2. should I use the whole 5 feet? and suggestions on a kick stand? step ladder maybe?
You are off to a great start with your equipment that you have why not insulate your boiler for shits and grins
You can just use a 2×4 with a v notch as a kickstand
- Deplorable
10g will be too thick to fit between the jacket and the vapor tube I think. Pretty sure I used the ground wire out of some 14/3 romex. It was a perfect fit.
I built mine 48" OAL with a 40" water jacket, and it was plenty long enough.
Maybe use the extra length of left over pipe to build a telescoping kickstand with a set screw to support the low end?
- Deplorable
I agree with Durhommer, wrap that keg with some reflectix or an old horse blanket to cut your heat up time.
- Tom Kat
I have a roll of duraflez and tape and will be adding it as soon as my condenser is done. AND SS, I will be sure to cover the top of the keg!!! thanks for all the help fellas...I do read and listen!!!
