CCVM still first time build
Hi guys, new poster but long time browser of the forums.
I'm just starting my first still build and a couple people said put pics up so I'll do my best.
I've settled on a CCVM as it seems a pretty simple build but critically, also seems to be an easy still to learn on and control.
So, boiler is an 11gal keg that's going to have 2x 2kw elements in, I've got the spear out and cleaned up the flange. I have ordered a 2" to 2.5" reducer to go from the keg flange to the 2.5" column that I will be making.
I have almost 7ft of 2.5" so once I've decided on the length of the column and cut it, I'll have a fair bit left to use for a PC if I want to.
At the top of the column, I really don't want to have to buy a 2.5" tee and another 3x tri clamps, not to mention have to make another 3x easy flanges...
So, do you guys think I would get the same result by cutting into the column around a foot down, and soldering in a piece of 2.5" at 90° to make my own tee for the take off/PC section?
Moose
Moose
Re: CCVM still first time build
2" Keg Flange
2.5" Easy Flange
2.5" Easy Flange
2.5" column, uncut
yes, you can make your own take off as you stated.
My first flute
My press
My twins
My controller
My press
My twins
My controller
I've never tried to solder in at 90 before, any tips?
Should I flare it a little to get a better surface area for the solder?
make your hole a bit smaller than your pipe. cope your pipe and make a jig that will hold the 2 pieces together.
My first flute
My press
My twins
My controller
My press
My twins
My controller
Thanks for that, the jig is a definite!
Clamps and bits of wood galore!
Would you say 10" down is enough room for the RC in the top?
10" for the shell will be fine. your RC bottom should be lower than your take off. 2" should be fine depending on your liquid volume and flow rate... but just get your coil some past the take off.
My first flute
My press
My twins
My controller
My press
My twins
My controller
Thanks Setsumi, that's just the advice I was looking for.
I'll update once I've made some progress.
Ok, so I mentioned copper packing for the column.
I have the usual, copper fine mesh material on rolls, that send to be a common packing.
But I also have some thicker wire copper mesh, more like chicken wire kind of thickness but in a woven mesh.
I'll clean some up and put up a pic when I get home from work.
Would I get any benefit out of using this intermittently between the finer stuff? Or instead of?
I was thinking of using a big ball of it at the base of my column as a support in any case, to prevent any of the finer mesh getting pushed down into the boiler. The 2" to 2.5" reducer will keep it in place.
Thick copper wire mesh
Comparison
Thoughts and suggestions guys?
If you're absolutely confident that the thicker mesh is 100% copper then that's what I'd try. I like the fact that a thicker mesh will hold a form ... so it's not going to compress and risk flooding (as can happen with the finer mesh).
That said, since you have a lot of copper in your spools then you don't necessarily need more as packing. Raschig rings, lava rocks, marbles all have fans here so don't be afraid to experiment.
________________
- Deplorable
I run 35 inches of this woven 4 strand copper mesh in my 2" column, and it consistently runs 95% . If I had another 5 inches of spool to increase my height I could probably put 2L/hour at that ABV. As it is I'm about 1.5L/Hour. Pushing any faster the ABV drops to 93 and starts to smear tails.
I'm as sure as I can be Gregg, it's not magnetic, cleans to a bright copper colour in acid, I've looked at a cross section under magnification and it's the same colour right through.greggn wrote: ↑Wed Jun 02, 2021 4:40 pm
Without getting some tested by spectroscopy I can't do much else can I?
Yes as you say it's more likely to hold form that's why I was thinking of using the 2 meshes in combination and definitely in the base, not knowing if it'd get a good result... but then deplorable replied!
Thank you Deplorable, this is exactly what I was hoping for!Deplorable wrote: ↑Wed Jun 02, 2021 6:15 pm I run 35 inches of this woven 4 strand copper mesh in my 2" column, and it consistently runs 95% . If I had another 5 inches of spool to increase my height I could probably put 2L/hour at that ABV. As it is I'm about 1.5L/Hour. Pushing any faster the ABV drops to 93 and starts to smear tails.
I "Found" this copper mesh, so I don't know what it's called or what it was intended for. Therefore couldn't search to see if others have used it.
Thanks for taking the time to post a picture of yours, that's super helpful.
I have been planning to cut my 2.5" column to 42" packed length, plus another 10" for the RC in the top.
If you are achieving those results with what you have, I'm absolutely stoked to get this thing up and running to see what it can do!!!
Do you think 42" packed at 2.5" is overkill?
Ok some bits I ordered to get started arrived, so I thought I'd throw up a couple more photos.
2" keg to 2.5" column adapter.
I had to shave the rim off one side of the PTFE seal.
Had to clean up my DIY flange as the face was full of dinks from the paen hammer. Mill filed, diamond honed.
It fits!!!
Now I just need to muster the courage to cut the column to length, then drill a 65mm hole in it a foot down to put a 90 in. This bit scares me.
It fits!!!
A question I had meant to ask about the packing.
Whichever mesh or combination I use, what effect does the "Tightness" of the packing have?
Is it as simple as, more dense can give higher purity but runs slower due to physical restriction?
So consequently, looser is faster but does not have as effective reflux action?
The pic that Deplorable put up shows pretty tightly rolled mesh. In my head the packing I was going to put in was more loosely rolled/balled up.
Just want to understand the difference from the huge pool of experience there is here.
If your packing is too tight you will have issues where the condensate is restricted in it’s return to the boiler. The risk is that condensate will build up and overflow via the offtake.
Purity will be high (until you get flooding) but rate of output will be low.
Not enough or too loose packing and you get less opportunity for mingling of the vapour with the condensate. This impacts on the rate of purification of the vapour. Rate of output will be higher but purity will be lower.
There is the happy medium to find. IMHO slightly less than optimal packing can be adapted for by higher rate of vapour flow. I find that less stressful than constant monitoring and tweaking vapour flow to avoid flooding.
You adjust the rate of vapour flow by adjusting the heating power to the boiler.
IMHO you’ll get better mingling of condensate and vapour if the packing is randomly arranged. That is to unroll the packing and tease it out and scrunch it up. The condensate will follow the easiest path to the boiler either down the walls or down the path between the layers in the rolls.
Modular 2" Pot Still
Thanks for this Kimbodious, I'm leaning towards using a combination of the 2 meshes I have, so based on your advice I think I'll get the finer mesh all bushy and wrap the thicker stuff intermittently around it so there's a nice structure to prevent it being compressed.kimbodious wrote: ↑Fri Jun 04, 2021 12:29 am IMHO you’ll get better mingling of condensate and vapour if the packing is randomly arranged. That is to unroll the packing and tease it out and scrunch it up. The condensate will follow the easiest path to the boiler either down the walls or down the path between the layers in the rolls.
By the way, your still design and explanations of it, is what made me decide on CCVM after loads of research.
I'm wanting to do neutrals, but I know I can also charge it to a pot still in a jiffy should I want to.
All good, glad I could help!
It is nice to have neutral spirit to make liqueurs etc but pot stilling is my joy. This is the beauty of modular systems, build what you need for the task ahead
Ok, an update.
I was bumbling around in the garden, and decided to pick some of the Rhubarb that just keeps coming through (I grow it for wine) when I suddenly remembered why you can't eat the leaves... Oxalyc acid!
So I threw some in a blender with a bit of water, poured out into a bucket and dropped a section of the heavily oxidised thick copper mesh in.
Rhubarb leaves
Rhubarb leaves
Tried to post a pic of the result, but can't seem to attach any more photos to the thread, have I hit a size limit?
MooseMan have you cut into your column yet for the T? Im thinking it would be easier just to use a 2.5" end feed T - no need for flanges or tri clamps. I use this on my 2" column and use a wrap of ptfe tape to seal the joints -works fine
Actually Rum, I've decided that to get the most out of my still and to make it more future proof so that I can enjoy it for longer, it's best after all to get a stainless tee and an elbow, so I've ordered them, along with the needed tri clamps.
It means I'll have to make another couple of easy flanges, but I think in the end I'll have a more versatile setup.
The decider was, that I found a place in the UK that sells a large range of sanitary stainless parts at very reasonable prices.
Great that you've taken the plunge - look forward to seeing your progress
- S-Cackalacky
MooseMan, good luck with your build! You'll probably finish yours before I do and I started mine in 2016. Been finished for the most part, except for a first spirit run. I look forward to hearing about your experiences running yours. Have fun and stay safe.
MooseMan put copper gauze in the search. Lots of info to be had.
Thanks gents, I'll keep posting updates as I go in any case.
Tackling the element ports in the keg later today.
Another little update then, I managed to find 2x SS 316 hose barb fittings at work (1" BSP)
I parted the hose barbs off on the lathe, to leave just a bolt, basically. I've done lots of reading and searching, and it seems silver soldering is an acceptable way to join Stainless together providing it's not load bearing.
So, I've turned a shoulder into them, to seat into the holes in the keg and provide more surface area contact and hopefully a stronger bond! Is there any sage advice from people who have soldered element threads in?
I've got kester liquid flux, I've got silver solder and I've got a (Pretty crappy!) butane/propane torch.
I've soldered a few connections now with silver solder. I'm using an oxy-butane rig, Rovista liquid flux for zinc / stainless, and a 3% Ag solder (Tin / Silver and nothing else). Knowing how long it takes to get to temperature using my oxy rig, I'd be wary about using a simple propane torch. If you can stomach the investment and can't get your hands on a oxy-gas setup then I would buy a simple MAPP torch. I successfully brazed chromealloy bike frames with a Bernzomatic MAPP torch. If you're in a largish town / city have a look for artist workshops. In Edinburgh there was a group that hired out workspace + tools to sculptors where I hired an oxy-acetylene rig for an hour to braze up two joints that were just too big for my MAPP torch. Or see if there's a local plumber who could be persuaded to hire you the tools. If you do decide that you want an oxy-gas torch, accept the pain and buy one with a rechargable oxygen cylinder. The throwaway cylinder kits seem interesting until you realise how quickly you burn through the oxygen bottles.
In terms of joint prep, get as close a fit as possible. In a perfect world they should be push fit and hold through friction without any visible gaps. In my experience, with a little practice you can fill some small gaps, but the more filling you're doing, the weaker the joint.
Thank you for taking the time to give me so much useful information regarding the heating, that's the bit I just can't get clear in my brain. I've even read of people using an iron and getting it done? Surely not?!NormandieStill wrote: ↑Sat Jun 12, 2021 1:09 am I've soldered a few connections now with silver solder. I'm using an oxy-butane rig, Rovista liquid flux for zinc / stainless, and a 3% Ag solder (Tin / Silver and nothing else). Knowing how long it takes to get to temperature using my oxy rig, I'd be wary about using a simple propane torch. If you can stomach the investment and can't get your hands on a oxy-gas setup then I would buy a simple MAPP torch. I successfully brazed chromealloy bike frames with a Bernzomatic MAPP torch. If you're in a largish town / city have a look for artist workshops. In Edinburgh there was a group that hired out workspace + tools to sculptors where I hired an oxy-acetylene rig for an hour to braze up two joints that were just too big for my MAPP torch. Or see if there's a local plumber who could be persuaded to hire you the tools. If you do decide that you want an oxy-gas torch, accept the pain and buy one with a rechargable oxygen cylinder. The throwaway cylinder kits seem interesting until you realise how quickly you burn through the oxygen bottles.
I do have a friend who is a heating engineer/plumber so I'll speak to him about this for sure and see what he's got.
I'm really hoping that I get a clean, perfectly round cut through the keg on the last cuts with the step drill, as I've settled on 36mm holes and turned a 35.8mm shoulder into the fittings hoping for a nice snug fit.
I'm also planning to seat the fittings and hammer them into the face of the keg to create a nice flat seat before soldering.
I guess I'll just try it, and if I fail I'll have to de-solder and get them welded (C. £60) locally.
I'll post pics of whatever the result is!
