my first still.....
CarmeloLabadie
my first still.....
Post by CarmeloLabadie »
I got a 2 gallon stainless cooker, put a 4" diameter funnel onto the lid with a 1/2" opening. From there it goes to 3/8" piping all the way through the coil. Is 3/8" too small? Is the funnel a good idea? I did it to try to capture more steam. Or is it better to just stick the tube straight through the lid? Thanks people. I don't yet know how to add pics or I would.
Corn Cracker
Re: my first still.....
Post by Corn Cracker »
How did you seal the funnel to the lid and how did you transition from the funnel to the 3/8 "piping"?
Buck Owens
subbrew
Post by subbrew »
the funnel will not capture more steam/vapor. The amount of steam is totally related to power input. Tube straight though the lid will mean one less joint to seal. 3/8 will work as long as you don't try and push it too hard.
3/8” ID is very small. You won’t be able to use much heat at all because the vapor through-put is restricted by the “vapor flow area”, that is, the diametric area of the tube.
3/8” tube = 0.110 sq.in.
1/2” pipe = 0.196 sq.in.
3/4” pipe = 0.442 sq.in.
1” pipe = 0.785 sq.in.
1.5” pipe = 1.77 sq.in.
2” pipe = 3.14 sq.in.
As you can see, larger diameter presents significantly more flow area. What happens when you try to push too much vapor through too small of tube/pipe by the heat input (which generates the vapor rate) is that the boiler pressure must rise. Increasing the boiler pressure will also increase the temperature at which the wash will boil and it also increases the danger of boiler rupture.
And the small diameter could be easily plugged by a “puke”, thereby increasing the explosion risk.
Another side effect of a small diameter vapor tube is that the vapor velocity will increase as the pressure drops through the tubing as a result of friction. When the velocity increases, it is difficult to transfer its heat into the condenser walls, potentially creating a “puffing”, or vapor exit at the spout.
A larger diameter vapor tube/pipe will increase the “dwell time” the vapor has in contact with the condenser wall, allowing it to give up its heat and condense. Also, you’ll be able to run it with more heat input (and faster vapor production).
So, I would NOT RECOMMEND using a 3/8” ID tube for your vapor tube. Use at least 1/2” ID tubing, preferably even larger.
And, no the funnel inside the boiler won’t do you any good. Forget about it.
dragon9874
Post by dragon9874 »
still_stirrin wrote: Sun Nov 28, 2021 9:19 pm 3/8” ID is very small
... tend to agree, but for a 2G pot, maybe not @SS?? take that back, shouldn't matter how much capacity the pot is, right?? durp! ;-)
My Journey Started here: Cranky's Spoon Feeding!
10G pot still + 3.5G thumper + 4G condenser... all copper! d-(^^,)
{DWDSD} \m/(^_^) \m/
