Welding versus soldering
I'm sure it's been discussed and even with all my reading, I've probably overlooked it, but what safety issues are related with welding of copper versus soldering of copper?
Re: Welding versus soldering
When done in a well vented area, none.
With proper fitment and a well executed procedure, none.
JMHO
JMHO
Guess I should have specified a little more... safety in regards to food and drink safety...would welding affect the consumable alcohols ... I know we use food safe solders...that was my concern.
After proper cleaning they are both safe.
AC
AC
Soldering is likely to be much easier and you can take it apart after.
Had to give up my oxy-acetylene, so all I have now is mig, stick or carbon arc - I don't think I'm good enough to weld copper gas-tight with any of those !
as long as you clean well. there is no difference. structurally, in general, welding is stronger if done right. however, soldering is more attainable for the average person.
I'm just the bank and the mule
post your still pics here
http://homedistiller.org/forum/viewtopi ... 16&t=66917
If you need more strength than soldering, you need to quit climbing on your still.
Yup !BugHunter wrote:If you need more strength than soldering, you need to quit climbing on your still.
