Lead and stainless
Lead and stainless
I know all the dangers of lead,
That being said, i was given a 15g keg from a crossfit place next door to our
plumbing shop.
It was full of water and what i thought was gravel till i dumped it out in the driveway. It was lead pellets and water. I swept up the pellets and bagged em to recycle. I think it formed a crust inside. Completely bummed i set it aside to deal with another day, went inside and made a drink.
Is there a safe way to clean all that out to use as a still or is it trash?
plumbing shop.
Buck Owens
Buck Owens
Re: Lead and stainless
Are you a “gambler”? Go ahead and “roll the dice”.Corn Cracker wrote: ↑Thu Jul 22, 2021 2:53 pm... Is there a safe way to clean all that out to use as a still …
Me … I’d look for a different keg.
I figured, had to ask for some opinions though. I know there's gunbore cleaners that break down lead but. .......
Buck Owens
Buck Owens
A 50/50 mix of white vinegar and hydrogen peroxide will totally dissolve lead without harming stainless. But..... then you have dissolved lead in solution (lead acetate) which is another problem. It's toxic through skin contact and disposal is a bitch. So that's probably not a good option. It could rid your keg of lead though.
Plain ole pot rig.
I hate to say this but you should destroy the keg beyond further use and recycle it.
drill it full of holes, take it to the shooting range and swiss cheese it. run it over
with a tank. make sure it can't be used in any form at all ever. I have a 100 ton
press and smashing it like a beer can comes to mind. please don't mess with it.
If you shoot you can probably find someone who will be happy to take the lead off your hands. I am sure someone at the range casts bullets.
- jonnys_spirit
Good idea! Fill it with thermite and start it up with some magnesium shavings! “Sac run for the ethanol gods”
I reckon I'll give the guy the option of taking it back before i shoot it full of holes and scrap it. Maybe I'll engrave a warning with skull and crossbones on it if he wants it back
Buck Owens
Buck Owens
I have engraved warnings on blue barrels that had nasties in them.Corn Cracker wrote: ↑Fri Jul 23, 2021 2:28 am I reckon I'll give the guy the option of taking it back before i shoot it full of holes and scrap it. Maybe I'll engrave a warning with skull and crossbones on it if he wants it back
- Deplorable
Hell yeah! Ive got a couple of pounds of thermite (not yet mixed) and some magnesium ribbon in the garage. I think I've got about 5 pounds of tannerite around here as well, but the thought of SS shrapnel frightens me. Melting a big damn hole in it sounds safer.jonnys_spirit wrote: ↑Thu Jul 22, 2021 7:43 pm Good idea! Fill it with thermite and start it up with some magnesium shavings! “Sac run for the ethanol gods”
Not sure where you are at. However my local beer distributor sells kegs. Legit, 30.00 apiece.
I suppose if you had to an angle grinder or even just a sawzall will cut it in half to make it unusable and keep it safe.
If in doubt leave it out.
Not to revive a dead thread, but i would turn it into a urinal or something similarly useful without being harmful.
Jstroke, where are you located? I would pick up 3 or 4 stainless kegs tomorrow for 30 each!!
You guys are so luck to get kegs for that cheap. Over here even a beaten up second-hand keg goes for a loooooot more.
I didn't make a still out of it, i do still have it though.
I did call the epa which directed me to the national lead hot line. I didn't say it was for distilling just asked if it could be safe to use again and she recommended just basic household cleaners would be fine to get it clean and safe for beer as the stainless does not absorb it so it can be scrubbed clean.
I have not decided on cutting out the top, cleaning it and making a boiling pot out of it or not, i am picking up another keg I'm going to use for the still.
Buck Owens
Buck Owens
I've got a plan for a thumper build when I'm ready for that addition.
Buck Owens
Buck Owens
Pre-heater?Corn Cracker wrote: ↑Thu Nov 04, 2021 3:39 pm I've got a plan for a thumper build when I'm ready for that addition.
No, i don't want to use that keg for distilling. It'll make a good keggle though. I have a stainless cylinder from a water softener system that I'm going to make into a thumper, if and when i need one.
Buck Owens
Buck Owens
