Mold on barley mash
850stealth
Mold on barley mash
Post by 850stealth » Tue Apr 06, 2021 1:06 pm
So I made 2 x 50liter mashes on April 1st, I checked on them a few times and all was good. Today I went to take a reading and one still had the grain on top and bubbling away slowly, the other had all grain dropped out and was covered with a thin white mold. I'm thinking I just need to dump this and take the loss but the reading is still good and it doesn't smell horrible. Pics attached. Never had one turn like this on me. Maris otter and honey gambrinus malt. I tried to attach pics but not sure how. No matter what I do it says file to large.
tiramisu
Re: Mold on barley mash
Post by tiramisu » Tue Apr 06, 2021 1:14 pm
No pics attached.
Master Distiller
Post by NZChris » Tue Apr 06, 2021 1:15 pm
Sounds like Lacto., I've never let that stop me running anything.
850stealth
Post by 850stealth » Tue Apr 06, 2021 1:18 pm
850stealth
Demy
Post by Demy » Tue Apr 06, 2021 1:20 pm
Do not throw away, try to distill the same, sometimes you will be amazed to get good things from "suspicious" ferments. If the FG allows it, distil.
Master Distiller
Post by still_stirrin » Tue Apr 06, 2021 1:21 pm
...the other...was covered with a thin white mold.
Probably not really a “mold”. More likely, a bacterial pellicle, from lacto-bacillus. This will sour the mash but will add a nice “signature flavor” once it’s distilled.
...I'm thinking I just need to dump this and take the loss but the reading is still good and it doesn't smell horrible...
I suggest waiting a while until it has finished fermenting. And then run it. In the end, you might just like it. Sometimes “mistakes” turn out nice.
850stealth
Post by 850stealth » Tue Apr 06, 2021 1:24 pm
Ok well this is better news than I was expecting. I think I'll strain it off tomorrow and let it all settle out then run. I'll be combining 3 runs to fill a 5 gallon barrel.
Demy
Post by Demy » Tue Apr 06, 2021 1:27 pm
Now I see the images, it seems an infection from "Candida Mycoderma" which is also common on wines. I believe your fermentation has been completed for a long time. Distill this as soon as possible
850stealth
Post by 850stealth » Tue Apr 06, 2021 2:12 pm
it's strange for it to be done so fast. The one beside it is still going. Either way I strained it off and now it's settling and I'll possibly get a chance to run it tomorrow night.
8Ball
Post by 8Ball » Tue Apr 06, 2021 3:05 pm
Run it. I’m interested in how it works out for you. Did you do 50/50 Maris Otter & GHM?
850stealth
Post by 850stealth » Tue Apr 06, 2021 3:08 pm
hopefully it will settle out by tomorrow night and I can run it. I did a 75% maris otter and a 25% honey malt. The wash was much darker than the previous 2 row I had made
8Ball
Post by 8Ball » Tue Apr 06, 2021 6:11 pm
Man, thats a lot of honey malt. I bet it will be sweet. I’m using 3% honey malt and the sweetness carries over nice. Looking forward to your updates.
850stealth
Post by 850stealth » Wed Apr 07, 2021 2:14 am
I will get a chance to run this tonight, it settled out nice last night in the cold temps. I just don't have anything to compare it to taste wise. I've never used these grains, all I really used was 2 row and that was a year ago.
Demy
Post by Demy » Wed Apr 07, 2021 8:55 am
I'm sure you'll get a good product. While in homemade beer it would be a failure, in distillation the fermentation of yeasts and indigenous bacteria can create a favorable aromatic profile.
850stealth
Post by 850stealth » Wed Apr 07, 2021 3:58 pm
I'm currently heating it up now, hopefully it turns into something good. My other one that's now ready also has the same thing starting on top and the cap just dropped last night. I've never seen this before. I'll need to run that one asap too, but at least it's moved to a cold area.
850stealth
Post by 850stealth » Thu Apr 08, 2021 7:28 am
Well I started running it last night and tan into all kinds of issues. I was running 2 pates and all was good and coming off at at 70% ABV. Then the power went out so I lost both pumps but heat stayed on because I use propane, I got the generator going and went to restart and the pump for my dephlegmator failed so I had to go into a stripping mode. I have 2 more mashes to run so I think I'll just strip the next one and then get a new pump and on the last one I'll dump all the low wines into it and run 2 plates for the final spirit run. The stuff I ran last night smelled great until the power went out then everything after that recovery just smelled like tails.
