Oats?
I just got done with a batch where I had reused the mash from the first( which consisted of mostly corn, sugar, and a small amount of rolled oats.) I put about 8.5 gallons of back set into the second mash along with 5 lbs of rolled oats, and 18 lbs of sugar. I made a run on sunday, I put 2 qts of whiskey from the first run in and by the end when the column temp reached a hair over 200deg I had collected 9 qts of product. I don't have a hydrometer yet so I can't tell you what the final proof is. What I can say is that the flavor profile is different from the first and that the oats contributed a positive effect to the flavor, I am still a neophyte to this so it is hard to give an accurate discription.
When doing the oats I added about 6 crushed tablets of beano and held a mash temp of 155 deg for an hour, I didn't do a starch test so I can't tell you if there was a full conversion.
Furball
Furball
Isn't there some bacteria on Rye and Oats that can produce poisonous substances when malting? If I was you I would just mash it with like 20% high enzyme Barley. Or buy professionally malted Oats.
From the site:
Jack advises ..
Malting for home use is not a difficult procedure, but it should NOT be attempted with oats or with rye.
These grains, when malting, tend to attract butryfying bacteria - these organisms, by themselves are poisonous, and so is the butanol isomers that these bacteria produce (see page 127 (for oats) and page 130 (for rye) in the book "The Homebrewer's Garden" by Joe Fisher and Dennis Fisher, Published in 1998 by Storey Books (http://www.storey.com onclick="window.open(this.href);return false;" rel="nofollow)).
From the site:
Jack advises ..
